It is currently Sat Jul 26, 2025 1:57 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: neck gap
PostPosted: Sun Dec 19, 2010 6:03 pm
City: Medford
State: Oregon
Thanks Chuck, I've used hanger bolts before for other things. I would imagine that they are easier to install, but are there any downsides to them?
PostPosted: Sun Dec 19, 2010 6:25 pm
First name: Hugh
City: Lake Oswego
State: oregon
Could the trussrod be interfering just a bit? I use the bolt, but not with a dovetail, it's hard visualizing both together.
PostPosted: Tue Dec 21, 2010 2:45 am
These work for me.
http://www.mcfeelys.com/product/3606-ST ... 3606-STS-D
You can also find them at McMaster-Carr.
PostPosted: Tue Dec 21, 2010 9:15 am
I've used the Cumpiano method from the start. A couple of years ago I did some pull out testing on trial tenons and posted the results here. Can't find the thread in the archives but basically the tenon failed in tension along the grain lines at a moderate torque without reinforcement. (Pictured below)
With inlayed maple or carbon fiber strips it I couldn't get the tenon to fail. They worked as a tension band and formed a very strong construct. I now inlay Maple strips in the tenon, flood the whole works with thin CA and feel reasonably safe. I'm sure other methods work equally well. I think the Cumpiano method has some advantage with higher neck angles as in archtops etc.
