It is currently Thu Aug 14, 2025 11:51 am
PostPosted: Mon Dec 13, 2010 8:24 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
Hello there i recently salvaged a broken robot coupe
for those who dont know what this is .....
its a heavy duty food processer thats got a 250w motor in it
and around 2 inches long of a 1/2" stainless hex shaft
I plan to turn it into a spindle sander
(ive heard that at this rpm it burns the paper but this doesn't matter because its
only for the very final sanding on forms )
Ive bought a sanding drum for chucking up to a drill press
thinking their was some kind of ingenious sandpaper locking device , their wasn't
Also ,from the pictures I thought from the picture it had a coupling to fit
the hex shaft on my motor .... it was round
Anyway
I managed to bodge a sleeve of cut pipe tight over the hex shaft and onto the drums coupling
turned it on only to find out its totally wobbley......
Basically i need a longer shaft for an axle at the top of the drum for stability
Ive looked EVERYWHERE for a 3" deep socket ,extension or coupling so i could mount it on the shaft
and fit a sleeve over that to make a shaft extension
The only other options i can see is to get some specialist to weld another extension on
or turn this project into a big one by attaching a pulley to the shaft and gettin more parts exc
Could i just remove the original shaft?
any suggestions folks ?
thanks in advance
tomas
PostPosted: Mon Dec 13, 2010 9:28 pm
City: winnipeg
State: manitoba
Country: canada
It sounds like an interesting project but my advice is to save it as a third of a horsepower motor and look on Craigs List for a spindle sander. Mine cost $75 and does things adequately.
Bob :ugeek:
PostPosted: Mon Dec 13, 2010 10:11 pm
First name: Mark
City: Concord
This small Oscillating Spindle sander from Grizzly has a 1/2" arbor. The rubber sanding drums may fit your application. An email to Grizzly customer service would confirm it.
http://www.grizzly.com/products/g0538/parts
I would hope the replacement sanding sleeves are available in Ireland.
After Googling those food processors I would try to trade it for a nice sander. They're the Rolls Royce of Food Processors!
PostPosted: Tue Dec 14, 2010 12:02 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Mcmaster-Carr.com?
PostPosted: Tue Dec 14, 2010 2:30 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
Thanks for the replys guys
after looking everywhere for a "hexigonal tubing" coupling it seems like its
cheaper to get/buy/find other parts than get it from the usa
It seems im gonna go the full hog and make up a seperate shaft
thats belt driven from my motors shaft attached to a frame by
2 pillow blocks the same as on a drum sander
with the pulley in between them
The only thing ive got to find out is what kind of bearing to get to mount the vertical
shafts weight on .
So far .the diameter of the new shaft is depending on this bearing
ive got a broken bits of a garden mucher /shredder
and i presume that it has a vertical shaft bearing
ill report back when i get a better idea on the new parts im trying to source
any suggestions appreicated though
espically on the pulley sizes as ive never done this stuff before
Thanks again
tomas
Users browsing this forum: pullshocks and 38 guests
