It is currently Fri May 08, 2026 5:55 am
PostPosted: Sun Dec 05, 2010 6:49 pm
This afternoon, I was gluing on a bridge. I was using hide glue and the LMI vacuum clamp. My craigslist vacuum pump seized up after 6 minutes. So, what do people think about the bridge. It seemed to be a perfect match dry fitting. Uniform squeeze out that had cooled and gelled. If it matters, it's bloodwood on sitka.
Unless the consensus is "no way" I suppose I'll try and string it up next week and see how it went.
Thanks for your thoughts.
Mike Lindstrom
PostPosted: Sun Dec 05, 2010 6:57 pm
Country: Romania
I think it might be fine. Some people attach bridges with hide just using finger pressure. I doubt many of them can keep it for more than 6 minutes :D Hopefully you did not try to slide or push on the bridge in the first few hours.
Build log
PostPosted: Sun Dec 05, 2010 7:05 pm
First name: Jim
Last Name: Kirby
Ditto. If the surfaces are well mated and the hide glue is properly made, a rubbed joint is adequate.
Jim Kirby
kirby@udel.edu
PostPosted: Sun Dec 05, 2010 8:07 pm
One more, "It's going to be fine!" If it was clamped for 5 minutes it will be a good glue job. It was time to take the vacuum off and clean up the squeezeout anyway.
PostPosted: Sun Dec 05, 2010 8:14 pm
I vacuum clamp for about 15 minutes, but I think that is extremely conservative.
The vacuum does seem to accelerate the drying of the squeezout.
As long as it's a good fit with no stress, there should be no problem
Another vote for it'll be fine from me
PostPosted: Sun Dec 05, 2010 8:43 pm
Thanks for the reassurance. I was just about to shut off the pump for clean up, when it quit. In the past, I've then reclamped for another 15-30. This was my first with HHG. I thought it'd be good but wanted to check. I do the bridges on ukes with HHG and finger pressure, but I figure SS tension makes it more of a concern.
Good to know I'll have it done for xmas. Now I've got to find a new pump.
Mike Lindstrom
PostPosted: Sun Dec 05, 2010 10:03 pm
I wouldn't let it go to a customer.
PostPosted: Sun Dec 05, 2010 11:13 pm
Thanks for the warning, Howard. Luckily, I don't have customers. This is for a relative, and they know I'm still learning.
Mike Lindstrom
Users browsing this forum: ChuckB and 10 guests
