It is currently Wed Aug 13, 2025 4:23 am
PostPosted: Tue Nov 23, 2010 2:22 pm
Is Koa considered an oily wood?
I am having crazing (alligatoring) and adhesion problems (I have never had this problem before with Mahogany, Rosewood, Ebony or Spruce) on some Koa ukes. Sprayed 2 coats of 2lb cut flake shellac. StewMac waterbase filler, sanding sealer and top coats.
Formerly know as Mandodiddle.
PostPosted: Tue Nov 23, 2010 2:40 pm
With all that stuff on top of the wood .. its not the wood. And no, koa isnt oily ... how does the waterbase filler sit on top of the shellac ??? I woudl think you fill first, then shellac coats then tiopcoats .. no sanding sealer requried. That stuff might be your issue ...
PostPosted: Tue Nov 23, 2010 3:04 pm
Tony,
Thanks for the reply. I'm not sure I follow you --- "How does the filler sit on top of the shellac?"
PostPosted: Tue Nov 23, 2010 4:26 pm
Well you say in this order .. 2lb shellac, then filler, then sanding sealer then top coats ... so I am asking how well does the filler sit on top of the shellac (or am i misinterpreting your order of ops there) ... does it flow out evenly ??? is there a bonding issue there ???
PostPosted: Tue Nov 23, 2010 5:01 pm
Tony,
It does seem to flow just fine. I am thinking that this interface between shellac and filler is the area of the adhesion problem.
PostPosted: Wed Nov 24, 2010 8:00 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
Koa isn't an oily wood but if it were, shellac would seal it. Your problem is incompatibility between
the shellac and the filler, I would think.
PostPosted: Wed Nov 24, 2010 9:50 pm
Why use sealer on top of shellac? What kind of sealer and how much of it? And what is the top coat? Sounds to me like too many layers underneath. It's not the koa.
PostPosted: Thu Nov 25, 2010 12:21 am
Yep, too much fat under the lean. All that soft stuff under your lacquer is the problem.
PostPosted: Thu Nov 25, 2010 12:40 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
No.
cron
