It is currently Tue Aug 05, 2025 12:13 pm
 Post subject: Bending Form Dilemma
PostPosted: Sun Nov 07, 2010 11:09 am
First name: Mark
Last Name: Schrier
State: Washington
I am helping a friend with his first build.
When building his forms, he made the decision to inset the 1/2" rods about 1/2" in from the edge of the form. His rationale was that the .010" tempered steel would be stiff enough, since it was bent and couldn't form a compound curve.
So when the sides came out the bender, they were cupped. Concave at the ends and in the flatter area between the waist and the lower bout. About a 3/64" in the width of the side.
Also, a convex bump between the waist and the upper bout.
I wasn't with him during the bending process, so cannot verify if his technique was a factor.
Was interested to know if anyone could confirm if the mold construction was the main problem.
Now that they are what they are, I am looking for the best solution to cure it, if possible.
I have offered to attempt flattening out the cupping on a pipe bender, which I I have used enough to be reasonably proficient, but am not sure if it will be capable of correcting the issue.
Any advice would be appreciated.
Mark
A world without music would Bb.
 Post subject: Re: Bending Form Dilemma
PostPosted: Sun Nov 07, 2010 11:52 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I think your friends' rationale is incorrect.
I'd suggest fixing the form, making the rods flush, and then re-bending the sides.
I have a question though: did he get the wood very wet before bending? That can cause cupping too.
PostPosted: Sun Nov 07, 2010 12:17 pm
First name: Mark
Last Name: Schrier
State: Washington
Yes, Jim. He did mention that he had soaked it pretty good. Certainly more than I would consider necessary.
BTW, his bender is a light bulb bender, built as a copy of the one I use.
So your suggestion is to put them back in the corrected bender?
Mark
PostPosted: Sun Nov 07, 2010 12:22 pm
I use 10 thou slats .. and there is no way I would ever trust them to stay flat across the shape without support when bending - he needs to fix the form. The rods are there for a purpose. even with them you may get some cupping - when making new molds I always go solid now .. it simply works better.
PostPosted: Sun Nov 07, 2010 2:51 pm
First name: Mark
Last Name: Schrier
State: Washington
Thanks for the responses. I had really felt the same way, but couldn't seem to persuade him otherwise. [headinwall] [uncle]
I am hoping to get some opinions on the best method of repair. Either rebend in a corrected mold, which is what Jim suggested or use a pipe bender which was my first thought.
Mark
PostPosted: Sun Nov 07, 2010 8:58 pm
Last Name: Killin
On the first and only set of sides I bent I didn't support the wood in between the sides of the form. I got some serious cupping. I ended up adding some support to the form and re-bending. It worked pretty well. This was with a light bulb bender for Uke sides. keep in mind with what I am saying that I have only successfully bent one set of sides. Hopefully that changes soon. :)
In this thread Todd suggests a way that I think will eliminate cupping without going full out solid form. I'm in the process of working this out on my new form now.
viewtopic.php?f=10101&t=29802
PostPosted: Sun Nov 07, 2010 9:52 pm
First name: duh
Last Name: Padma
Cupping is good!
Yes, is true. If it wern't for cupping you would never learn how to do it the right way....
simple eh!
blessings
duh Padma
PostPosted: Mon Nov 08, 2010 7:02 am
Don't soak the wood ,that isn't needed a light spray of water is all you need. Also is this rift or flat sawn ? That won't help matters. It won't matter if you used .020 thick if the wood is going to cup , it will if you have bad wood. It is normal to have some cupping so plan for it. A .010 cup is fine that will sand out a .030 is too much and you have to use some tricks of the trade to make them appear flat.
I use a .015 tempered stainless slat , these will hold very well on a curve. Shim stock stainless is a different alloy and there is a difference between 301 and 302 stainless when it comes to hardness , flexibility and support.
PostPosted: Mon Nov 08, 2010 9:17 am
First name: Mark
Last Name: Schrier
State: Washington
Thanks for the info, John.
The sides are a beautiful set of quartersawn EIR with an excellent match to the back, so I am really motivated to find the best way to save them.
Mark
Users browsing this forum: DanSavage and 42 guests
