It is currently Sun Aug 10, 2025 7:40 am
PostPosted: Tue Nov 02, 2010 5:19 pm
I have gotten a fairly good handle on router cutting body binding and purfling. I would really like to do a headstock like a Les Paul Custom, or high grade acoustics by some makers. Long ago, I was taught how to do a layup of a headplate with purfling held around the plate with an army of pushpins. It would then be glued on and then the headstock routed or "gramiled"(I've only done it long ago with a shopmade Sloane Gramil) for the taller, outer binding installed with mitering and cussing and sweat and tears.
Is there anyone here who now has developed a Dremel/ lam trimmer or Foredom method for routing the steps around the headstock? Perhaps this is the one task where the StewMac screw-on binding head would really work?
Thanks, Mike
PostPosted: Tue Nov 02, 2010 5:58 pm
Nuts. Just cut out the headstock plate and bind it. Sand flat and glue it on the neck.
It's the way I've done these for many years.
PostPosted: Tue Nov 02, 2010 6:57 pm
First name: Tom
Last Name: West
State: Nova Scotia
Haans: Thanks for that,so simple and easy.
Tom
PostPosted: Tue Nov 02, 2010 7:12 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I simply use my Williams-style binding jig. You may have a lot of complicated bending and mitering, depending on the shape of your headstock, but cutting the ledges is the easy part:
PostPosted: Wed Nov 03, 2010 7:12 am
I use the stew mac cutter set with the headstock face down on the router table ...
PostPosted: Wed Nov 03, 2010 8:42 am
+1
Haans (or others pre-binding your headplate) ...what headplate thickness do you use typically.
Milton, ON
PostPosted: Wed Nov 03, 2010 8:52 am
I second Haans, no routing necessary. Binding & purfling the headplate before gluing it has always seemed the easiest/no-nonsense way to me.
I start with a .100" thick headplate/binding/purflings to come down to .070".
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Nov 03, 2010 4:29 pm
Depends on the purf and binding. Sidebound (I'm doing one now) runs around 1/8" to start and I take it down after I get the inlay in. If it's just topbound, I usually go around .1"...
PostPosted: Thu Nov 04, 2010 8:05 am
Okay, I've got to ask Haans and Laurent, how do you cut your head plate so that when it's bound, it fits your headstock? Would seem especially difficult on those fancy mandos.
Joe
PostPosted: Thu Nov 04, 2010 1:10 pm
I rout the rabbets on the headstock after shaping it. No jig needed since the surface is two dimensional; the laminate trimmer sits on the flat surface of the headstock, the bearing rides on the side.
PostPosted: Fri Nov 05, 2010 5:28 am
LIke this, Joe...
Cut off the scrap on the bandsaw after glueing and final trim with a sanding drum in the drill press.
PostPosted: Fri Nov 05, 2010 7:35 am
Glue the finished headplate onto the uncut headstock, so simple.
You know when you're used to harnessing the horse a certain way, it gets hard to visualize an alternate method. :D
Thanks Haans,
Joe
