It is currently Sat Aug 16, 2025 11:17 am
PostPosted: Thu Oct 14, 2010 3:58 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Occasionally I need to widen a saddle slot on a bridge - or in the future, cut my own slots on custom bridges (I've been purchasing and altering Martin Belly Bridges to my personal shape up to now).
What would you recommend for a jig to accurately cut these slots.
I saw this product on Stewie but I wish it had micro adjustment wheels for really dialing it in.
http://www.stewmac.com/shop/Tools/Speci ... es#details
Anybody out there make something better?
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Oct 14, 2010 5:11 pm
Check here, Todd Stock shows a nice one that he built. viewtopic.php?f=10101&t=29329
Chuck
PostPosted: Thu Oct 14, 2010 5:47 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use the Stew Mac jig, with a Bosch Colt laminate trimmer. A picture's worth a thousand words.
PostPosted: Fri Oct 15, 2010 12:09 am
First name: Aj
Last Name: White
City: Hangtown
Also bit the bullet and went for the Stew Mac jig, made incredibly well and works just as good. The way I do it is you keep the rear "stopper" set, and to do the widening passes you slip a steel shim in between them however thick you need to widen the slot so you can cut pretty accurate with it.
PostPosted: Fri Oct 15, 2010 7:47 am
Stew-Mac jig. It's worth the $$.
PostPosted: Fri Oct 15, 2010 9:47 am
First name: Martin
Last Name: Lane
City: Grand Rapids
Mine is not "better" but it cost me nothing and it worked perfectly. I have a small collection now of homemade jigs made from scrap pine, and I'm leeery about warpage, but they work for now. As I gain more experience and cash I'll replace them with jigs that won't warp or wear as easily.
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Fri Oct 15, 2010 12:21 pm
Last Name: Redmiles
City: Woodbridge
State: VA
Zip/Postal Code: 22192
I made this out of various aluminum plate and linear bearings I found on ebay. Very precise, and the stops allow getting the dimensions of the slot just right.
The vertical part unbolts, and attached to a fixed base, becomes my binding routing jig as well.
PostPosted: Fri Oct 15, 2010 12:42 pm
Last Name: Burner
City: Lincoln
State: Nebraska
This is quite substantial and very impressive.
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Oct 15, 2010 2:39 pm
Last Name: Charnock
Country: UK
Could be a silly question, why not route the channel before gluing the bridge ?
PostPosted: Fri Oct 15, 2010 2:55 pm
Last Name: Burner
City: Lincoln
State: Nebraska
I'm agreeing with your question.
What if you mess up? If it is off the guitar then you have recourse.
If it is on the guitar then you have problems.
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Oct 15, 2010 3:32 pm
First name: Martin
Last Name: Lane
City: Grand Rapids
I find it easier to get the intonation better, by routing after gluing the bridge. Having a slot in the bridge already, and putting it down in just the right place is harder, IMO, than placing the bridge ballpark and then cutting the slot precisely where you want it to be.
PostPosted: Fri Oct 15, 2010 3:37 pm
Last Name: Redmiles
City: Woodbridge
State: VA
Thanks Paul. I was delighted to find out that carbide bits do a fine job on aluminum as well as wood.
I like to rout the slot with the bridge glued in place because I can get the most accurate saddle location that way. I'm a player as well, and very fussy about proper intonation. It's just easier for me and more accurate to locate the saddle point for each string with the bridge glued in place.
PostPosted: Fri Oct 15, 2010 3:38 pm
Last Name: Redmiles
City: Woodbridge
State: VA
Users browsing this forum: doncaparker and 11 guests
