It is currently Sat Aug 16, 2025 5:30 pm
PostPosted: Thu Oct 07, 2010 9:23 am
First name: Corky
Last Name: Long
City: Mount Kisco
For my first commission (YAY) my client is interested in a celtic knot rosette (pictured).
What's your recommendation for inlaying this into the top? Am I literally going to have to manually trace and route the miniature curves on the perimeter of this rosette? (yikes).
Thanks!!
PostPosted: Thu Oct 07, 2010 9:37 am
Rather you than me!
Set it into a channel with Black Mastic, possibly with purfling lines in the outer and inner circumference.
PostPosted: Thu Oct 07, 2010 9:57 am
Route out a circular channel the width of your rosette and drop in the rosette and a few drops of CA to glue it in. Then mix some epoxy with black die and fill the gaps. Sand flush after its dried and voila.....seamless! You can also do purfling lines if you like.
PostPosted: Thu Oct 07, 2010 10:21 am
First name: Corky
Last Name: Long
City: Mount Kisco
Peter, Michael,
Perfect. I use dyed epoxy for inlays on the fingerboard. Can do! Thanks.
PostPosted: Thu Oct 07, 2010 10:48 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
As the others said.
I might think about trying that black epoxy from stew-mac.
Hey Corky, where did you get that?
I love the shape, and Paua is my fav color at this time.
Alan
PostPosted: Thu Oct 07, 2010 11:39 am
I would seal the periferal area of the rosette with shellac first to avoid ending up with a grey soundboard after sanding.
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Oct 07, 2010 11:43 am
Hi Corky,
just a caution. I have had the black epoxy bleed into my top wood, so purfling bands help to isolate the epoxy. Also, a mask around the area is a good idea.
Craig
PostPosted: Thu Oct 07, 2010 12:13 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Great idea on the purfling, sealing withshellac, and the mask. I definitely want to be very careful with this - it's a special top I'll be using.
What I've done in the past is use either zpoxy or System Three epoxy, mixing in System Three black epoxy paste pigment - think I got it from LMI. Man, does a little of that stuff go a long way.
Last question - So, after I've carefully spit coat on top with shellac as protection, routed the rosette channel, set the pufling and rosette, spot glued with CA, then masked and carefully filled the gaps with black epoxy.....
after totally dry and hard, is the right technique to pass it through the drum sander to level it? If so, what grit sandpaper would you use?? Is there any risk of the epoxy heating up, and staining the other parts of the top?
PostPosted: Thu Oct 07, 2010 12:35 pm
First name: Christopher
Last Name: Scott
Drum sander? wow7-eyes
I would just use a scraper to get things level. A sharp scraper and some time. Drum sanding would be too scary for me.
Christopher
PostPosted: Thu Oct 07, 2010 12:36 pm
Last Name: Scott
Christopher
PostPosted: Thu Oct 07, 2010 1:47 pm
First name: Todd
Last Name: Lunneborg
City: Andover
State: MN
Zip/Postal Code: 55304
Vinal sealer works too, and seal after you've routed the channel, inside and out. Don't worry your glue and epoxy will still stick.
Todd Lunneborg
http://www.tlguitars.com/
http://www.fretboardjournal.com/
PostPosted: Thu Oct 07, 2010 2:33 pm
If you don't want to cheat you can always go the Al Carruth route.
PostPosted: Thu Oct 07, 2010 2:37 pm
I would use the drum sander to a point where the rosette would be almost level with the top (.010 or something like that). Than finish up with a scraper.
Alain Moisan
PostPosted: Thu Oct 07, 2010 2:48 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Thanks, all!
Great advice.
PostPosted: Thu Oct 07, 2010 4:20 pm
Looks like an inlay from Andy DePaule.
http://www.luthiersupply.com/pearlrosetteinlaypage.html
He also has some suggestions or tuts on how to.
Not to mention he's a good guy to deal with.
PostPosted: Thu Oct 07, 2010 4:37 pm
WOW!!!
PostPosted: Thu Oct 07, 2010 4:49 pm
I would inlay it into a separate piece of ebony or perhaps the back/side wood and then inlay the assembled rosette into the top. This will lower the risk to the top.
PostPosted: Thu Oct 07, 2010 4:52 pm
Check out Alan's website and you'll be amazed. i yhink Alan said it took something like 21 plane jigs to make the parts but I'm not sure if there were more for the ablam field.
PostPosted: Thu Oct 07, 2010 5:18 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Yes go Andys site !
I take his roses and peel the plastic off from them and set them in the
pre-routed channel still glued to the card they came on .
In epoxy .
The channel has to be the same size as the inlay!
1/2" or what ever size it is !
Let set overnight & sand,scrape the backing off.
Then cut the outer & inner purf. channels
Glue them in and level the rose !
Mike Collins
PostPosted: Thu Oct 07, 2010 11:25 pm
First name: alan
City: Santa Rosa
State: ca
Thanks, Chris!
