It is currently Thu Aug 07, 2025 3:43 pm
 Post subject: laminate trimmer
PostPosted: Sun Aug 29, 2010 8:52 am
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
Hello all im thinking of getting a laminate trimmer for cutting binding channels and rosettes, the one im looking at is the bosch gkf 600 im in the uk and i think its called the colt in the states, i used a dremel with a jig i made that registered off the sides for the binding on my first guitar but found it a bit under powered so was wondering if i could make the same sort of jig for the bosch (the problem im thinking of is fixing the bosch to the jig) allso does anyone know if there is a circle cutting jig available for the bosch, any opinions would be appreciated thank all Rob
 Post subject: Re: laminate trimmer
PostPosted: Sun Aug 29, 2010 9:39 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
For the circle cutter, make one of these Wells/Karol precision circle cutter jig for a laminate trimmer for yourself:
http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=18858
[:Y:]
PostPosted: Sun Sep 05, 2010 3:32 pm
Last Name: Charnock
Country: UK
I went with the Makita - I think it is the 3704. It works fine in the Stewmac binding jig.
PostPosted: Sun Sep 05, 2010 3:34 pm
Last Name: Charnock
Country: UK
PS
Personally I would stick with the dremel for the rosette and sound hole - I found it to be a delicate task and the heavy laminate trimmer may not be harder to control.
J
PostPosted: Sun Sep 05, 2010 4:25 pm
My PC 310 in a Wells jig produces MUCH cleaner and precise results for rosettes than my Dremel ever did.
PostPosted: Sun Sep 05, 2010 5:42 pm
+1 on what James said
PostPosted: Sun Sep 05, 2010 9:24 pm
I've got quite a few... the Colt, Makitka, PC, Ryobi.... they all work well. My favorite is the Makita (3707FC), but the PC is close. The ryobi is a distant last.... The colt is a nice unit too, but I've heard some stories of inconsistencies.
PostPosted: Mon Sep 06, 2010 7:11 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
+2 on what james said.
never used a colt,
but that 310 is a good tool.
i really like the shape of the base, and the height adjustment.
very accurate.
all my pc tools have been workhorseys,
PostPosted: Mon Sep 06, 2010 7:42 pm
I use a dremel with base and circle cutter from http://www.tonetechluthiersupplies.co.uk/Tools/Dremel-Tools-and-Accessories/View-all-products.html for rosettes and a Bosch 600 (colt) for bindings - built my own binding jig.
Dremel and base seems to work fine for the rosettes as long as you don't expect to take big bites.
Bosch has the power for binding ledges, no problems there. But I couldn't find a decent fully adjustable circle cutter in UK.
Nice not to have to change routers from one jig to another, but if you're using just one, make your own circle cutter as suggested, and binding jig is even easier to make.
I'm sure any of the laminate trimmers mentioned would make a fine tool with the wells-karol jig for rosettes, maybe I've just been lucky with the dremel, but works fine so far. When it expires I'll maybe go for the Proxxon, still small and light to handle, but better built.
PostPosted: Mon Sep 06, 2010 11:36 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
John mentioned inconsistencies with the Bosch Colt & I have found one very annoying trait with this otherwise excellent tool.
It is fine used on my binding jig, or whenever you are working with a bearing bit. When using it with the base against a fence I have found a problem. Every time I re-set the depth, the bit changed it's position, relative to the base. Really frustrating when making several passes to achieve a desired depth of cut.
I'd be interested to hear if anyone else has had the same problem.
Personally, I find Dremel tools disappointing for precision work. They are OK when gliding along with the grain, but as soon as you change direction & start fighting the grain, the light bearings & shaft allow for too much runout.
I built my rosette router jig before the Wells jig made the scene. It was designed around an ancient Makita 1/4" router. I don't find the size & weight a detriment at all. Actually, I think the extra mass helps.
PostPosted: Wed Sep 08, 2010 6:33 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I use the ridgid on my welles jig & the hand held binding jig whose name escapes me now even though I had to drill my own mounting holes. The guy from precise bits said it had the least run out of anything out there. I have yet to try it on my .025 bit from him.
MM
Mike McNerney
PostPosted: Thu Sep 09, 2010 4:46 am
I have bought the GKF 600 from Axminster and I am about to start binding my 2nd guitar.
I'm trying to adapt one of the bases for the task. I will post some pictures and let you know of the results .
Users browsing this forum: bftobin, Bing [Bot], ptourin and 7 guests
