It is currently Tue Aug 12, 2025 7:39 pm
PostPosted: Sun Aug 29, 2010 5:16 pm
Last Name: Thiessen
City: Lexington Park
I have a Tele type electric I am building with a 5 piece maple/walnut neck. I had originally planned on putting a headstock veneer on it so I took it down to 7/16" I am now really liking the look of the 5 piece neck on the headstock with the 6 inline tuners cutting across it, so I was wondering if that is too thin to just leave or if it would be ok. Its seems plenty strong.
On another note, the tuners I bought for it need at least 1/2" so if I leave it I can either double up the washers or grind down the threads or something, which is better?
thanks
John Thiessen
http://www.iszacguitars.com
PostPosted: Sun Aug 29, 2010 6:31 pm
Seems a bit thin to me. I'd put either a headplate or backplate on it. I personally would not go less than 1/2", but thats just me.
Chuck
PostPosted: Sun Aug 29, 2010 6:44 pm
Last Name: Thiessen
It has an 8 degree headstock angle on it so I am not worried about the break angle of the strings. It is not an exact Tele, it is my interpretation of a Tele.
John Thiessen
PostPosted: Sun Aug 29, 2010 7:21 pm
I usually go 9/16" on the headstock thickness when building a tele.
PostPosted: Sun Aug 29, 2010 7:28 pm
Last Name: Kincheloe
Is it for yourself, or a customer? For yourself, might as well keep it, and glue it and add a plate if it breaks. For a customer, I'd probably give it a plate, or ask them which they'd prefer. And of course fix under warranty if it breaks.
Tuners, I would grind down the threaded inserts.
PostPosted: Mon Aug 30, 2010 3:15 am
I've got a tele I did with a thin headstock, and it's been fine with the string tension. The problem lies with the tuners. I had to put extra washers under the nuts to get then tight so they won't rattle, and it looks really bad.....
Rob
Users browsing this forum: peter.coombe and 32 guests
