It is currently Tue Aug 12, 2025 5:00 pm
 Post subject: Q on making bridge pins
PostPosted: Sat Aug 28, 2010 6:02 pm
First name: Brent
Last Name: Gilligan
City: Washington
State: NJ
Zip/Postal Code: 07882
hi,
Started playing around turning some bridge pins. I was wondering if there was some math
I could use to come up with the tapper. I have some bought pins with a 5 degree tapper that I could measure but I am turning slightly larger pins for sub bass strings on my first harp guitar build.
Brent
PostPosted: Sat Aug 28, 2010 6:10 pm
IMO you dont need larger pins for the subs on a harp .. the largest string is about 76, or possibly 80, and I use a std pin on the low B of my baritones which is a 70 .... I wouldnt go larger. What you wil need is a larger wider ramp for the string to sit in ... the pin will just hold it there. I am using 3 degree pins from Gurians ... they do have a larger bottom than the 5s obviously ... but you still need a 3/16 hole for the ball end to fit thru ...
PostPosted: Sat Aug 28, 2010 10:09 pm
It's pretty near impossible to make them consistently on a wood lathe. With a metal lathe you set the taper angle with the compound slide.
Users browsing this forum: Kbore and 23 guests
