It is currently Tue Aug 12, 2025 7:32 pm
PostPosted: Thu Aug 26, 2010 1:41 pm
First name: Heath
Last Name: Blair
City: Visalia
i designed a guitar using G thang and then exported the file to rhino CAD as a .dxf file. im having a hard time finding someone to print it out to the proper scale. no luck at kinkos. no luck with the CAD guy at work. he got it close, but not close enough for me. how do you guys print reliably from rhino and other CAD software?
sweat the small stuff.
PostPosted: Thu Aug 26, 2010 3:25 pm
Look for a place that specializes in architectural/construction documents, "reprographics" is probably a good search term. Other than that, you just have to make sure you're not scaling your print to fit the page or anything like that. I don't know anything about Rhino specifically as I use Autocad.
PostPosted: Thu Aug 26, 2010 5:17 pm
In a pinch you can print from Sketchup, but the process can be hit or miss and involves taping individual pieces of drawing together. Maybe try searching for drafting printing as well. You could also send the file to a cnc guy and have him cut it out of hardboard or plexi.
Bob
PostPosted: Thu Aug 26, 2010 7:15 pm
I haven't messed with rhino much but, what I do when I need a big print is export to PDF with whatever size paper I need and upload it to Kinko's with directions that it must be 1:1 scale. I always put a control marks in there to measure in the x and y axis to make sure it's indeed 1:1 (usually some tick marks about 10cm apart).
The key is to specify that you must have 1:1 and then make sure you specify 1:1 when you export the PDF. If when you pick it up it's not 1:1, refuse to pay until it is.
PostPosted: Thu Aug 26, 2010 9:45 pm
First name: Heath
Last Name: Blair
City: Visalia
well, i finally got a print that is relatively close. within about .030" or so. not too bad.
andy, how do you export to .pdf from rhino? i cant find .pdf as an option in the drop down menu of file types.
PostPosted: Thu Aug 26, 2010 10:34 pm
As I mentioned, I don't use rhino much. I've only played with it a little bit but, if it doesn't have a PDF feature built in, there are free software packages that let you trick the software into thinking it's sending to a printer but the software intercepts and creates a PDF.
Cutepdf at http://www.cutepdf.com is the one I used to use. You'll want to do a test run or two to make sure it's coming out 1:1 though.
PostPosted: Thu Aug 26, 2010 10:57 pm
First name: Heath
Last Name: Blair
City: Visalia
that worked, andy! at least creating the pdf did anyway. thanks!
PostPosted: Fri Aug 27, 2010 8:37 am
Last Name: Garrish
+1 on PDF printers
They're also super useful for getting off of paper permanently; I pretty much only print to PDF now for records unless it's a mail-in form or something (redundant backup, of course!).
Bob Garrish
Users browsing this forum: No registered users and 44 guests
