It is currently Fri Aug 01, 2025 10:47 am
PostPosted: Wed Aug 18, 2010 1:11 pm
or a pre-slotted 630MM fingerboard?
Elman
PostPosted: Wed Aug 18, 2010 1:24 pm
I'll post it here too. Google up wfret. It prints a fret scale that you can cut out and double stick tape to the fingerboard, then cut on the lines. Easy as pie. You do have to check to make sure it's right, but it also prints the measurements from nut to each fret and from fret to fret. I usually check the full length, and length to 12 with a ruler then check some intervals to make sure everything is right. Here are a couple of pictures. I cut the slots with one of Shane's slotting blades on my RA saw, but a hand saw and miter box would work fine.
PostPosted: Wed Aug 18, 2010 5:04 pm
If you already have some of the standard fretting templates (or fretboards), you can check and see if omitting or adding (a) fret(s) at the nut end will get you 'close enough' to your desired scale.
PostPosted: Wed Aug 18, 2010 7:36 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've got a 24.75" template. That's 628.65mm. If that's close enough I'll be glad to slot one for you.
PostPosted: Thu Aug 19, 2010 7:17 am
Thanks Guys for the ideas and the offers.
Users browsing this forum: meddlingfool and 41 guests
