It is currently Tue Aug 12, 2025 12:06 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Aug 17, 2010 10:46 am
Fully recovered, now from re-topping #5.
Installed top purflings and bindings.
Tapered my fingerboard then put in toothpick pins, then slotted them.
Checked the action to find that I needed to do some additional tapering on the board, which is what I expected, but better safe than sorry. Will taper after gluing it on.
Glued it down with epoxy.
PostPosted: Tue Aug 17, 2010 11:30 am
First name: Nathan
Last Name: Swanger
City: Mechanicsburg
State: PA
After (re)making my fretboard it got pinned and glued.
Believe me, i'm about as surprised as all of you that it actually starting to resembled a guitar laughing6-hehe
PostPosted: Tue Aug 17, 2010 12:19 pm
Thanks for the kind words, Peter. I just saw your two guitars. They are looking sweet. I look forward to hearing what they sound like.
Regards,
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue Aug 17, 2010 7:05 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Nice stuff Foster, Burton, and John! I got my LP to the point of bursting and spraying. With a little luck, I'll get the burst done this week. Probably will end up applying by hand rather than spraying the burst.
Ken
http://www.casperguitar.com
PostPosted: Tue Aug 17, 2010 7:58 pm
First name: Stuart
Last Name: Gort
Finished up a series of vacuum plates.
viewtopic.php?f=10106&t=28656
StuMusic
PostPosted: Tue Aug 17, 2010 8:30 pm
Filippo (and Joe!),
I am not sure I have ever seen that exact graft treatment but I have seen enough so much like that I see it as a style I am co-opting rather than something unique. I like it too, the plastic made it so easy. A little acetone and the joints disappear! I can't wait to see it with the color.
On the saw I am planning to give it the full treatment. At least as much as I am able to. I will have a little help, which I will need. I got the full cast iron doors with it but I may make something that will show the shape more, it would be a shame to hide it I think. I am helping a friend restore a giant 36" saw from the late 1800's and this 20" seems like a baby next to that thing! In reality the 20" saw is not too much bigger than a run of the mill delta style 14" saw, the C shape keeps it compact. It came with a Brazilian (I think) rosewood ball on the tensioner also, which I think is pretty cool. And I also think it is geeky to think that is cool, but I still do.
Max, those purfs and the rosette look great.
Burton
Brookline, MA.
PostPosted: Wed Aug 18, 2010 6:17 am
Building a new neck for a 12-string electric, the original is too twisted to play or level out. Got the fretboard bound and epoxied to the neck. First time using non-wood binding, it sure was easy to bend. Busy time of year, not getting much time in the shop :(
PostPosted: Wed Aug 18, 2010 8:17 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Max, Peter and Ken I guess I need to get in touch with Paul Murphy and plan another Blue Fish get together.
Fred
Fred Tellier
PostPosted: Wed Aug 18, 2010 11:56 am
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
MaxBishop wrote:
This last weekend I put together my first rosette. This is a traditional mosaic/veneer lines type. Heres some "rope" I made for edge treatment.
And here's the rosette.
Max
Does anyone have a preference between routing individual channels in the top and laying them in as you build the rosette, vs, the above approach of building on a separate scrap as a single piece, then just routing a single channel?
I do the first (route each channel), but the above looks tempting. I'm wondering how you keep constant inward pressure on the rosette to keep "lumps" out of the lines?
PostPosted: Wed Aug 18, 2010 1:07 pm
Steve ,
Might be better to start another discussion on that where more would answer. I'd be interested to hear more on Spanish Rosette construction and methods as well.
PostPosted: Wed Aug 18, 2010 2:03 pm
Got another Selmer-type guitar ready for the finish guy. Claro walnut body, english walnut neck, cedar top, African ebony bindings/fingerboard/headplate.
PostPosted: Wed Aug 18, 2010 2:31 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
The selmer looks great PZ. It would be nice to see more of it. I've always liked Claro and can't wait to see it under finish. I take it that it will have a tail-piece and a floating bridge? (never having built one myself...)
Who does your finishing? Nitro? Waterbase?
Peter
PostPosted: Wed Aug 18, 2010 4:19 pm
Here's another pic. Colors are really washed out from the sunlight but you get the idea. It will have a floating bridge and tailpeice when done. I'm having Addam Stark in Santa Cruz, CA do the finishing in Nitro. Can't wait to play it...
Regards, Peter Z
PostPosted: Wed Aug 18, 2010 5:38 pm
Last Name: Kincheloe
Woohoo, after a trip to the hardware store for some new drill bits, and some work on my dad's drill press since my hand drill can't take such large bits, I now have the neck attached bliss
Also got the tuner holes drilled, headstock partially cut out, and roughed out the heel.
The neck is attached by barrel bolts, with a countersunk washer followed by regular washer, to give it a bit of springyness in variable humidity.
It's really starting to look like a guitar now, with the fingerboard pinned on too. The fingerboard extension lies almost perfectly flat on the top, way better than I was expecting to do with all my eyeballing and approximations. However, I do need to angle the neck back to get about 1/8" higher at the bridge, so then it will have a bit of a gap, but probably just about right to avoid a "ski jump" after things stretch a bit with the strings on. The important thing is that it's nicely level with the top at the neck joint.
Next up is cutting off the sides of the neck shaft, and finishing the headstock.
PostPosted: Wed Aug 18, 2010 6:43 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
No pictures, but got the windows installed in the shop and the gable end vents, as well as the eave vents. Getting close to the insulation point and then drywall. It's been slow going but I can't wait.
Burton: Very cool old Crescent. I've been wanting one for a long time too, but now I have a 19" Grizzly and just couldnt justify needing another. I do have a Crescent 12" jointer that I went through a big resto on. I'm sure you arlready know all about the OWWM site. Very helpful guys there.
Darrin
PostPosted: Wed Aug 18, 2010 7:20 pm
I finished up a little classical loosely based on FE 17.
http://www.booneguitars.com
https://www.facebook.com/pages/Stephen-Boone-guitar-builder/488208541257210
PostPosted: Wed Aug 18, 2010 8:45 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Mr Boone, that is Sweet! [clap]
Love the mitered purfling treatment on the backstrip, very elegant.
PostPosted: Wed Aug 18, 2010 9:58 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Exceptional, Stephen!!
PostPosted: Thu Aug 19, 2010 1:24 am
Getting ready to bind #2. Just need to level out the sides.
PostPosted: Thu Aug 19, 2010 7:23 am
First name: Pete
City: Eden Prairie
State: Minnesota
Looking good James!! I can't wait to see it under finish. The figure will really pop!
Steven, Great work on the FE17 copy. Really a nice instrument! Any chance that we can hear how it sounds?
Peter
PostPosted: Thu Aug 19, 2010 7:58 am
Your build looks real nice James.
Robbie, Ken, and Peter,
Thanks a bunch for you remarks. I might get to record with it a little but the client is coming today to pick it up and I have two mini-planes to make so I just don't know. I can tell you however that it does not sound like a small guitar. I am extremely happy with the volume and tone of this instrument. Torres deserves all the accolades he gets and more.The guitar is staying here in town so I may get to record with it later. It is so much smaller than standard that I have a hard time playing it.
Thanks go out to forum members Douglas Ingram and John Abercrombie for help with information regarding the build.
There sure is a lot of nice work shown here in the forum and that is a fact. It is very inspiring.
PostPosted: Thu Aug 19, 2010 9:20 am
You got that right, Stephen. What is the purfling on that guitar that you so nicely mitered? [clap]
PostPosted: Thu Aug 19, 2010 10:49 am
Steve,
I would be most interested in hearing what others' experiences are in building rosettes "in situ" on the guitar top versus making them separately and then install them in one piece. If you don't want to start a new thread I wiil.
Stephen,
Great looking guitar! How did your flamenco turn out?
Max
Max Bishop
Brighton, Michigan
PostPosted: Thu Aug 19, 2010 10:55 am
I build them up on a bread board, but then route the whole channel and move them piece by piece to the top. I suppose I could glue them and move them, but never even thought of it. I just like to make sure I know what I'm doing before starting on the top. Since I re-topped #5, I might have to think on that, as I moved the rosette, and that part was pretty easy.
PostPosted: Thu Aug 19, 2010 11:13 am
I just opened one so more people can find the question.
Users browsing this forum: No registered users and 41 guests
