It is currently Tue Aug 12, 2025 12:05 pm
 Post subject: Masking Tape Damage
PostPosted: Tue Aug 17, 2010 1:20 am
Last Name: Charnock
Country: UK
I am centering the neck on my OM, and to save marking the top with a pencil I put some masking tape over where I was marking the center and edges on the top. When I removed the tape it puled some fibers, it sanded out OK but I am concerned that when I mask the top where the bridge and neck locations extension are later on I will have the same problem.
I am considering a coat of shellac, will this have to be scraped off when I glue the bridge ?
 Post subject: Re: Masking Tape Damage
PostPosted: Tue Aug 17, 2010 2:00 am
First name: Gary
Last Name: Palmer
Country: England
Yes.
PostPosted: Tue Aug 17, 2010 3:20 am
Country: Romania
Put not one but maybe 2 or even 3 coats of blonde shellac whenever you deal with glue spills (bindings for example) or masking tape. Darker shellacs can stain the spruce too deep to sand without making waves that will be visible under finish.
If you do this under the bridge, make sure you scrape it *all* off with a razor, scalpel, chisel etc something very sharp. Need to do this right before gluing.
Build log
PostPosted: Tue Aug 17, 2010 6:10 am
Lay the tape on your shirt or t-shirt before you put it on spruce next time. Or gently heat the tape before you pull it (45º to the fibres…).
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Aug 17, 2010 6:23 am
You are learning that you have to watch the grain direction. you can use tape just pull in the direction with the grain.
PostPosted: Tue Aug 17, 2010 12:28 pm
Last Name: Abercrombie
I keep a good-quality 'drafting eraser' handy (the soft white kind from K&E) and it gets rid of pencil marks quite well.
Soft top wood will 'imprint' (under French Polish) from pencil marks even through masking tape- something I learned when recently lining up the neck on a cedar-top guitar.
So a soft pencil is advised if working with cedar. Spruce is a lot tougher in this respect.
PostPosted: Tue Aug 17, 2010 1:46 pm
Use Scotch 2080, not 2090.
Users browsing this forum: No registered users and 44 guests
