It is currently Fri Apr 17, 2026 6:49 am
PostPosted: Thu Aug 12, 2010 4:55 pm
I have a can of Sealcoat that is dated 06-22-09. I purchased another can recently and the stamped code reads "Lot S0413A". Has the manufacturer changed their dating system. I am not sure how to interpret these letters and numbers. Any ideas?
PostPosted: Thu Aug 12, 2010 8:10 pm
Last Name: Abercrombie
I interpret it as a deliberate ploy on the part of the manufacturer to hide the date code from the consumer, but I don't think that's the answer you are looking for!
PostPosted: Thu Aug 12, 2010 9:03 pm
You may be right. This particular batch tends to gum up sand paper.
Over many years of using the Zinsser, I have never had it go bad-the "Seal Coat"-I have not used the "Shellac."
PostPosted: Fri Aug 13, 2010 9:32 am
My problem with Seal Coat has been that it eats through the can bottoms. I had a gallon in my shop, that I used, from time to time when I needed spit coats while working a top, or for coating jigs, but not for FP a guitar. Here's where it ended up. I walked in the shop, and smelled something funny, and saw this. It was already dry. The bottom of the can around the edges was mush.
This was the second can. I caught the first one leaking, and poured the stuff into a new can from HD, and thought it was a fluke. Apparently not! gaah
PostPosted: Fri Aug 13, 2010 1:00 pm
Last Name: A
french polished concrete
PostPosted: Fri Aug 13, 2010 1:11 pm
Gives the floor a nice patina, don't you think?
PostPosted: Fri Aug 13, 2010 8:13 pm
WELL? Did you rub it up with wool in linen or the less trustworthy laundered "T" shirt material? :)
PostPosted: Sat Aug 14, 2010 2:26 am
I had the same thing happen Waddy. Thought it was just a one off but obviously not.
Bob Connor
Geelong, Australia
PostPosted: Sat Aug 14, 2010 5:57 am
Same thing happened to me with one can, Waddy. I couldn't figure out how the bottom could have gpttem punctured. Now I understand.
Max
Max Bishop
Brighton, Michigan
PostPosted: Sat Aug 14, 2010 4:12 pm
You guys are makeing me want to go and check my can bottoms! :roll: laughing6-hehe
PostPosted: Sat Aug 14, 2010 6:08 pm
I was about to post the other day about the very same thing! I"ve had TWO cans leak out, one of them dripped all of its contents off the edge of one of my tables, and onto the newly refinished hardwood living room floor (Yikes! I haven't told the boss yet!) It's a big gummy blob now gaah
Ken Mitchell
Durham, NC
PostPosted: Sun Aug 15, 2010 10:40 am
First name: Chuck
Last Name: Kish
City: Saratoga Springs
Zip/Postal Code: 12866
Me, too! Seems mroe than a coincidence....
Chuck Kish
PostPosted: Sun Aug 15, 2010 11:01 am
I checked my cans which are quart cans and there is no indication of failure on mine so mabey it's just the gal. size that's effected. idunno
PostPosted: Sun Aug 15, 2010 12:13 pm
First name: Chuck
Last Name: Kish
Mine was a quart.
Chuck Kish
PostPosted: Sun Aug 15, 2010 9:11 pm
Last Name: A
I guess finding a Tuppperware to put the can in now is a priority - I keep mine inside the house as well...
PostPosted: Mon Aug 16, 2010 10:34 am
Tupperware would be a good idea. Rubbermaid has some pretty good containers that I use for my shellac that I mix, which would be good, but, they only hold about a pint. I'm sure they make a quart container that would seal tight too.
