It is currently Wed Aug 13, 2025 2:52 am
 Post subject: router collar question
PostPosted: Wed Jul 14, 2010 11:16 am
For those of you with more experience with router collars, is it possible to use them to create a negative of a template? What I mean is, is it possible to use a combination of bits and collars to create a body mold from a body template?
Jason
PostPosted: Wed Jul 14, 2010 11:32 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Chris Paulick has a very good you tube tutorial on this. I have been using this method and it works well. Sorry I don't have the link
http://goatrockukulele.com
PostPosted: Wed Jul 14, 2010 11:36 am
Sure .. you just need to figure out the math .... from the original template, you are going to be routing away from it the bit plus the half the delta between the bit and guide collar. You want this to be a small number, so say we use a 3/8 guide and 1/4 inch bit .. so your total offset is now 1/4 plus half the delta of 1/8, which is 1/16 - total is 5/16. Now to use this new template to create a mold piece, you need to have the bit edge to be 5/16 inside the collar (or the bit to collar delta is twice this ) So if we need a delta of 5/8, use a 3/8 bit and a 1 inch collar or similar.
PostPosted: Wed Jul 14, 2010 11:37 am
Yeah, I've seen his video and it's very informative. However, he shows how to create a gap. I'm looking to create inside or outside molds/templates that are negatives of each other.
Jason
PostPosted: Wed Jul 14, 2010 12:17 pm
Just be aware that you cannot do this if there are corners or sharp bends in the pattern.
PostPosted: Thu Jul 15, 2010 6:56 am
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
You need to get a template guide kit to fit the base plate of your router. What you want to do is very common and quite simple. T
PostPosted: Thu Jul 15, 2010 7:28 am
Another optionis the inlay guide kit .. it has an extra bushing that provides the offset to give the inner/outer dimensions in the correct value ... Lee Valley amd even Home Depot here in Canada have them ...
PostPosted: Thu Jul 15, 2010 8:27 am
I've done this using bondo
First bass I built, first commision too, I had a mishap with the router, took a chunck out of the neck and fingerboard while nearing completion of the instrument. wow7-eyes
What I did to fix this was:
1) create a smooth curve template, something like a section of an ellipse.
2) use this template with a pattern router bit, (the one with ball berring on the shaft) to give that nasty wound on the neck a smooth profile of the ellipse like shape.
3) Create a negative of the router template using bondo.
4) Use the negative template to route a patch piece from another piece of maple.
5) Glue them together.
6) As for the fingerboard, added binding.
Actually I'm amazed at how well the repair came out. You can tell it's there because the wood grain is different, and the way the maple reflects light too. but the fit is tight, and the customer still happy with instrument.
Another lesson, Don't take on commission jobs untill you've got the chops to pull them off! duh
Cheers,
Stefan
PostPosted: Fri Jul 16, 2010 8:31 am
Thanks everybody. Those inlay kits from Lee Valley look pretty cool.
Jason
