It is currently Sat Aug 09, 2025 11:25 pm
 Post subject: Side bending sandwich ?
PostPosted: Tue Jul 06, 2010 4:11 pm
Last Name: Charnock
Country: UK
Hi
I have seen conflicting configurations of heating blankets and slats for bending sides. Such as
slat - wood - blanket - slat
slat - wood - slat - blanket
slat - wood -slat - blanket - slat
Which is correct, number three is out as I only have two slats
J
PostPosted: Tue Jul 06, 2010 4:24 pm
I use number two, from the inside out.
PostPosted: Tue Jul 06, 2010 5:03 pm
#2 for me.
Jimmy Caldwell
PostPosted: Tue Jul 06, 2010 6:05 pm
blanket/slat/wood in paper/slat/blanket
PostPosted: Tue Jul 06, 2010 8:13 pm
Last Name: Speller
City: Rodney
another vote for #2.
PostPosted: Tue Jul 06, 2010 8:57 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
I too use 3 slats
Slat / Blanket / Slat / Wood / Slat
John Ressler
PostPosted: Wed Jul 07, 2010 2:11 am
number 1 for me.
PostPosted: Wed Jul 07, 2010 7:47 am
First name: Bert
City: Gainesville
State: GA
Zip/Postal Code: 30506
"Try to be the person your dog thinks you are."
http://sites.google.com/site/bertsguitarshop/
PostPosted: Wed Jul 07, 2010 8:17 am
#2...but I also use 3 light bulbs to heat the opposite side.
PostPosted: Wed Jul 07, 2010 8:26 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I use #2 but add a strip of 6" aluminum flashing material to protect the blanket from abrasion caused by the ram and the spring loaded bending pieces.
Fred
Fred Tellier
PostPosted: Wed Jul 07, 2010 9:04 am
I use the steel wood steel blanket. I have yet to rub through a blanket. In most cases , as I bend about 250 sets a year , that is over 500 cycles and I use 2 benders . I have replaced 1 blanket that was about 4 years old and was my first prototype. I actually wore through the cord as that came off at the side of the blanket near the waist cawl. The 2 blankets I now use are about 3 years old and still work very well.
Protherm is a true industrial product. We used their equipment when I worked as a machinist in a plastics extrusion division. The silicone took quite a beating and we have very few failures as compared to other heaters. That is why I use them. They are a bit more but they are a quality item.
I agree there isn't a problem if you want to use the 3rd slat but it isn't needed . Still I know how some builders are , so I do think Alum flasing would be just fine for the top friction slat.
john
PostPosted: Wed Jul 07, 2010 11:37 am
Last Name: Charnock
Country: UK
HI all
Thanks for your input, I'll try slat - wood - slat - blanket.
The blanket instructions do say do not use in an open environment, resting on the top slat is rherfore not cosidered to be an open environment then ?
PostPosted: Wed Jul 07, 2010 3:20 pm
State: Hessen
spring steel/blanket/slat/wood in craft paper/slat/blanket/spring steel
for me.
PostPosted: Wed Jul 07, 2010 7:45 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I'd really like to pick up another blanket and use the same method as Christoph.
Most common method for me has been slat/wood/slat/blanket/slat
until I lightly scortched a side of Koa on the outside surface and spent way too much time sanding. For the 2nd side I
switched over to slat/blanket/slat/wood/slat to compensate for that problem and it worked fine.
Tim
PostPosted: Wed Jul 07, 2010 7:50 pm
putting the blanket under the slat is a good way to scortch . I place them on the top. The key is to use the blanket to heat the slat . Check out the bending video on youtube http://www.youtube.com/results?search_q ... ues+creek+
The one thing you will see that there are many ways to do this. Wood is an idiot and doesn't care how many blankets you use. In most cases , the people that need 2 blankets are using a 2 1/2 watt per inch blanket that cannot handle the thermal load. A 5 watt per inch is what you should use. It has enough power to handle the load.
If you feel you need 2 blankets than use 2 but after 10 years of bending , I can do it fine with one. I bend 250 sets a year. A good process will give you repeatable results.
