It is currently Mon Aug 18, 2025 8:08 pm
 Post subject: Hand powered table saw
PostPosted: Tue Jun 08, 2010 8:02 pm
First name: Curtis
Last Name: Olson
City: Hamilton
State: VA
I saw this on another forum. What do you think? (I have no affiliation with this)
Cheers,
Curtis Olson
Hamilton, VA
PostPosted: Tue Jun 08, 2010 8:18 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
might be cool!
PostPosted: Tue Jun 08, 2010 8:22 pm
City: Tucson
State: AZ
Bout one of the best ideas I've seen for sure. And the fact that it works THAT well is just icing on the cake for the one who designed it. I'm real happy for them. However, at over a grand I'll keep my saw, but if I were in the market for a table saw forget it, I'd be saving up for one of those because that's just a superior machine in every way.
PostPosted: Tue Jun 08, 2010 8:23 pm
Last Name: Abercrombie
Cool idea, but, really.....$1300 for an inverted miter box?
Whew.......
But it would look good in the shop next to the same company's $300 combination square and $860 block plane.........
PostPosted: Tue Jun 08, 2010 8:31 pm
First name: ron
Last Name: atkins
City: ottawa
State: il
Zip/Postal Code: 61350
it's pretty cool.
but it's $1200! :shock:
rono
PostPosted: Tue Jun 08, 2010 8:36 pm
First name: Curtis
Last Name: Olson
City: Hamilton
State: VA
OK, I admit it, my real scheme was to get everybody to notice it's cool factor, and then decry the price, hoping that one of our resident machinists would whip up a tutorial showing me how to make one. Might result in a patent lawsuit, though. [xx(]
Cheers,
Curtis Olson
Hamilton, VA
PostPosted: Tue Jun 08, 2010 8:59 pm
That is super cool. While watching I was thinking, oh yeah this is going to be overpriced though, like 800 or something. :)
PostPosted: Tue Jun 08, 2010 10:28 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
A great idea, not really that hard to build one out of plywood and stuff though. I mean its essentially an inverted miter box. Could even jig a japanese pull saw with a saw guide for ripping or even resawing...
Typhoon Guitars
PostPosted: Tue Jun 08, 2010 11:39 pm
Last Name: Shanklin
City: Windsor
State: ON
Pretty cool, but it doesn't have a SawStop on it. laughing6-hehe
Bob
PostPosted: Wed Jun 09, 2010 12:29 am
Bob
Hey Bob! I thought of saying that!! (but restrained myself....here we go again! laughing6-hehe laughing6-hehe )
"Hand tools aren't any safer; it just takes more persistence to really injure yourself!"
(I said that!)
bliss
PostPosted: Wed Jun 09, 2010 12:31 am
It seems to me that the really 'slick' feature is the spring-loading on the saw with the up-angle. Also, it looks like you really need an extra-long blade to make it work??
Go to it! (and be sure to post pictures here)
PostPosted: Wed Jun 09, 2010 1:23 am
Good idea but the big question, how long will it stay accurate for?
The devise looks to have been made from pressed steel or alloy, plastic fittings, and nylon gears. I am guessing here but it does not look like they have used true linear bearings. If this is the case then the blunter the saw became the more force you will need to use to make a cut and this exertion may cause uneven wear of slide bearings quite quickly. I would then expect that after a bit of use all those wonderful clean cuts they show in the vid would become more and more difficult to achieve. I am sure they have all the parts that can refurb the unit as required, but at $1300 with the ripping and depth limitations that come with it, you would need to stop and ask yourself, is a good old noisy tablesaw a better option? For me at least the answer would most certainly be a resounding yes.
PostPosted: Wed Jun 09, 2010 9:48 am
First name: Devin
Last Name: Cox
City: Edmond
State: Oklahoma
The prices scare me, but that company has some of the sexiest tools ive ever seen!
Valid concerns Kim. Their website has lots of verbiage but little information.
"The Jointmaker Pro v2 is identical to the original JMP in every way with the exception of the linear table design–the JMP v2 features a recirculating linear bearing system (the bearings follow a closed loop). They do not need adjustment (factory assembled) and they do not require lubrication. The main advantage is they are easier to use (much less friction) at the expense of a bit more noise. The acetyl bearings are much quieter than steel bearings and we are thrilled with the results. The tables feel effortless and are easily used with one hand."
So which is it using, the acetyl or the steel bearings? It's now smoother and takes less effort, but its now noisier.
The only other bit I could gather is that the static table is made of extruded aluminum.
From what they are charging to assemble it for you, it must be a bugger to put together.
Odd thing though is I can't find a review of either version by someone who has had their hands on it. Lots of commentary of course, but that's par for Bridge City Tools in general. Most of what I've read seems to follow what's been said here.
If someone stumbles across a real review, please post a link.
I have to admit that I really want to get my hands on one to try it out. It would be a wonderful addition to an off the grid shop. Or for someone that has their shop in their house and has to schedule things around their family because the noise is a big issue.
PostPosted: Wed Jun 09, 2010 10:11 am
I've not seen this one, but a friend of my dad's had a bunch of their other tools and boy were they sweet. Beautifully made and worked really well.
Mike Lindstrom
PostPosted: Wed Jun 09, 2010 3:11 pm
First name: Peter
Country: England
Filippo Morelli wrote:
Chris Paulick will fab one up in no time ...
Filippo
I was actually thinking the same thing...
Awaits Youtube clip to pop up :lol: .
Doesn't appear to even be on sale in the UK, if it was it would probably work out to be the equivalent to $1800+.
PostPosted: Wed Jun 09, 2010 4:06 pm
First name: Devin
Last Name: Cox
City: Edmond
State: Oklahoma
this link might be of interest..... (c;
http://festoolownersgroup.com/other-tool-reviews/the-complete-'jointmaker-pro'-review-a-paradigm-shift-in-woodworking/msg45126/
PostPosted: Wed Jun 09, 2010 7:00 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I think that is a beautiful design (saw stop jokes aside ;) ) I would love to have one!!
Mike [:Y:]
PostPosted: Wed Jun 09, 2010 7:28 pm
First name: Darryl
Last Name: Young
State: AR
While I woul dnever pay $1,300 for one, I've got to admit I would love to have one! It's a perfect fit for luthrie where you constantly need to make precise cots on small pieces. Just think how much safer this could be for cutting our a pyramid bridge blank or Rosette pieces. If it were $250 - $300 I would be in a quandry.
PostPosted: Wed Jun 09, 2010 9:38 pm
Thanks Devin, that's exactly the kind of review I was hoping to find.
PostPosted: Wed Jun 09, 2010 11:10 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
They could offer it at that price too if they outsource production to China... they just have to create a higher demand for it.
Typhoon Guitars
PostPosted: Wed Jun 09, 2010 11:42 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It is amazing to me this "explosion" in "botique" tools. However, it is not a power tool nor is it suited to a production environment. At $1300, it is doomed. It is not a replacement for the table saw... it is an evolution of the mitre box. And an excellent evolution at that.
One has to wonder where the "volume" buyer will be found that will pay for the R&D and bring costs down for the rest of us. Would I like it in my arsenal? Dam straight. But I have always resented the fact that the real money is in the tools, not the end product (witness the various gold rushes and hardware stores, and need I say anymore?)
PostPosted: Thu Jun 10, 2010 12:10 am
First name: duh
Last Name: Padma
I want one, please.
duh
Padma
PostPosted: Thu Jun 10, 2010 5:32 pm
First name: Peter
Country: England
Would be great to cut mortise & tenons for necks.
PostPosted: Thu Jun 10, 2010 9:55 pm
The headstock angle could be cut. It cuts 45 degrees in one direction and 15 degrees in the other. Depending on how you do your tenon, it could be cut as well. The neck block and the tail blocks are a given.
The fret board might require a fret barber for the fret wire, but it looks do-able.
Kerfed linings wouldn't require a jig. Check out the Squiggle Wood Video
Make reversed linings, regular linings or cap them.
The only part I'm not sure if they could be done would be long ripping cuts, like for the neck blank.
I want one, even at the 1200.00 sticker price. I lose a lot of shop time because of the noise factor.
Users browsing this forum: guitarjtb and 9 guests
