It is currently Sun Aug 10, 2025 10:53 am
 Post subject: Alvarez 5014
PostPosted: Mon Jun 07, 2010 7:06 pm
I recently rejuvenated a 70's Alvarez 5014. Short scale OM. Horrible top belly, bridge lift, needed a neck re-set, frets, hole punched in the side etc. Converted it to a double tenon bolt-on, neck re-set, new frets, new nut, repaired loose braces and the hole, installed a bridge Dr, converted to unslotted bridge pins, etc. etc. I left the strange adjustable saddle but even with that the guitar sounds absolutely great! It could hold it's own with any sub $1000 guitar. I was not familiar with this model and really didn't expect this result. I would guess converting it to a fixed saddle would really make it a keeper. Were all 5014's this good?
Terry
 Post subject: Re: Alvarez 5014
PostPosted: Mon Jun 07, 2010 8:50 pm
A lot of work there Terry and it sounds like you fixed her up right! Yes,I think I would
replace that adj. saddle (a lot of weird stuff came out in the 70's)but I don't know a lot
about these either.Good Job!
PostPosted: Mon Jun 07, 2010 9:30 pm
Thanks Dave The owner thought it was ready for the dump and I kind of took it on as a low pressure challenge. If I screwed up he didn't really care. I never would have guessed in a million years it would sound and play as good as it does. I'm guessing the 5014 was a good guitar when new. I'm thinking the owner will be back pretty quick to have it converted to a fixed saddle.
The neck and end of the truss rod were totally encased in epoxy. I had to remove the end of the fretboard to get it off.
I took an X ray of it before so I pretty much knew it would be trouble
This was kind of cool. There was a golf ball sized hole punched into the lower bout with 80% of the wood still there. I made a patch of 1/32" hobby store plywood and sandwiched it between two curved cauls with a threaded rod coming out where I removed a piece of wood. Tightening it down pushed the side flat and held the patch against the inside. I replaced the wood after I removed the cauls. It worked quite well. I still have to clean the area up and fill the gaps where there was veneer missing.
PostPosted: Tue Jun 08, 2010 4:16 pm
Wow, Those X-rays are great. Some repairs can be a real challenge!
I wonder How someone could encase the truss rod nut in epoxy like that? It
couldn't have come from the factory like that, could it? :lol:
Nice job on the hole patch Terry.
PostPosted: Tue Jun 08, 2010 5:48 pm
It actually adjusted at the headstock Dave so that's the butt end of the rod. Yes that's the factory job, almost the entire mortise was filled with epoxy. I was able to drill through it with the fretboard off and fell into an open cavity below the tip of the dovetail so I stuck a steam needle into that and the epoxy slowly softened and it came out. It was quite a mess. Converting it to a bolt-on worked well.
PostPosted: Tue Jun 08, 2010 9:54 pm
Ahh,I see what you mean now. verrrrry interesting job....
Thanks.
Users browsing this forum: No registered users and 39 guests
