It is currently Thu Aug 07, 2025 10:08 pm
PostPosted: Sat Jun 05, 2010 8:51 am
Last Name: Charnock
Country: UK
Hi
I was too eager to glue the braces I forgot to cut the the shape first, do you think it will cause any problems ?
PostPosted: Sat Jun 05, 2010 9:34 am
Last Name: O'Melia
City: Huntsville
State: Alabama
No. You cut it oversized anyways...
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
No problems. It's easy enough to trim back, braces and all on a band saw.
PostPosted: Sat Jun 05, 2010 9:35 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
This shouldn't cause you any problems. If you are using a band saw, and you put a curved profile on
the braces, you'll need to hold the back such that the edge being cut is sitting flat on the table- otherwise
a tooth might catch and yank the back down against the table, or break a chip out. Other than that, I
think you're fine.
Gene
PostPosted: Sat Jun 05, 2010 9:38 am
I can't imagine why it would be a problem. I've been letting my braces overhang the top/bottom outline before gluing and then trim them on the bandsaw, this should be pretty much the same.
edit: wow, talk about instant answers laughing6-hehe
PostPosted: Sat Jun 05, 2010 9:53 am
I recently started to do it that way intentionally.
PostPosted: Sat Jun 05, 2010 10:57 am
First name: David
Last Name: LaPlante
How you trim the edge all depends on your back gluing method. If you are using clamps with purely downward pressure, it's OK to leave some extra (1/4") at the edge. This also make the trim cut less critical as regards to chipping.
If you are using elastic bands or cord to apply pressure, that extra lip will lever up the joint and prevent a good bond. In this case the back needs to be trimmed as closely as possible to the side profile.
PostPosted: Mon Jun 07, 2010 8:24 am
I've made far far worse mistakes than that in my excitement in building guitars :D
Like most mine are always oversized too. Quick trip to the band saw boom done.
Users browsing this forum: No registered users and 42 guests
