It is currently Sat Aug 09, 2025 1:10 pm
 Post subject: Wood Rosette Thickness
PostPosted: Fri May 14, 2010 5:53 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
I want to put a wood rosette into my latest build something I haven't tried yet. How thick are your wood rosettes? Can you use wood veneer material? Your input is greatly appreciated.
PostPosted: Fri May 14, 2010 6:16 pm
Rosette and purf lines are usually .080" for me.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri May 14, 2010 6:52 pm
I like to go 0.060"+/- thick on my wood rosettes.
PostPosted: Fri May 14, 2010 8:54 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Yeah, that's the range I use.
http://www.casperguitar.com
PostPosted: Fri May 14, 2010 8:58 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Thanks for the input I'll give it a try.
PostPosted: Sat May 15, 2010 7:03 am
When doing wood rosettes , I use a separator at the edges. To get nice clean lines I make the rosette channel first. I then cut the wood for the rosette using the channel to set my cutter. Once I drop in the rosette I will use black or a colored purfling just to help frame the rosette. Some woods need it. This way I can set the rosette in without being to fussy with the final fit.
If I want to use just plain wood I make the rosette and use a scrap piece to make my cuts before hitting the top. I no matter how careful you are this is one job that takes some time. Set the cutter a bit shy of your rosette , that way you can nibble to your edges and get a tight clean fit. Nothing is more frustrating that hitting a coat of finish and seeing your finish sink into a void on the edge of your rosette. I also use a new bit for this job.
PostPosted: Sat May 15, 2010 8:29 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Make sure your top, and rosette material are both properly seasoned and stable before installing the rosette. If the rosette is too "wet" or "dry" it can shrink, or expand after installing, and cause all kinds of problems. For thickness I normally make the rosette around .080" or so. I install it at 1/2 the final thickness of the top, the scrape it level. IE, .100" top .050" rosette.
