It is currently Sat Aug 09, 2025 8:45 am
PostPosted: Wed May 12, 2010 5:43 pm
First name: Ellison
City: Whitman
State: MA
This may be a dumb question. I have no idea. I've done my first few finishes with nitro, and have not used shellac before. I've started a new project and will be installing a spalted maple rosette in an adirondack top. I've heard of people coating the top with shellac before routing the rosette channel. Can I do this and still finish the guitar with nitro? Can I leave the shellac on the top? Sand it off? How thick of a coat or coats can I or should I put on if this is possible? Thanks for your help, folks.
PostPosted: Thu May 13, 2010 2:53 pm
First name: Brendan
Last Name: Dwyer
City: tolland
State: CT
Zip/Postal Code: 06084
Todd Stock wrote:
Almost anything goes over or under shellac - it's a barrier coat. Shellac is often used as a sealer coat under nitro.
ok, so here's an even dumber question! :)
Could i put shellac over a sanded nitro finish and then spray KTM-9 waterbased laquer over that?
thanks!
bren
brendan 3.0 new and improved, with better interpersonal subroutines
PostPosted: Thu May 13, 2010 4:39 pm
thanks!
bren
You probably could, but why would you want to? You'd have to let the nitro cure for a very long time to let is shrink mostly (still shrinks over the years), then do the shellac, then the WB. Three different finishes isn't really the best idea. If you're already putting down nitro, why worry about WB? idunno
I usually spray 2 coats of shellac on the entire body before starting the build coats of finish (WB or nitro to date). If you're sealing the top before installing the rosette most of it will come off when you are leveling the rosette, bindings, purflings so you may have some residue in some areas. Try and get the top uniform with the seal coats before proceeding to the build coats, but it's not totally critical.
PostPosted: Sat May 15, 2010 10:52 am
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Does glue stick well to shellac?
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Sat May 15, 2010 11:26 am
glues do not stick well to any finish medium
PostPosted: Sat May 15, 2010 12:42 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I agree, most wood glues do not stick well to shellac. CA is one exception.
