It is currently Sat Aug 09, 2025 12:11 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 06, 2010 9:48 am
Alain Moisan wrote:
douglas ingram wrote:
I make my own. It really is easy and fast. I am also of the mind that if I am making a guitar, I am making the whole guitar. I also don't buy pre carved necks or bridges, slotted fingerboards, etc... Many peopled do, I'm not putting them down, but it just never occurs to me to buy that stuff.
Ditto.
Ditto (...maybe it's a Canadian thing! ;) )
(I did a tutorial long time ago on reverse style if anyone's interested)
Milton, ON
PostPosted: Thu May 06, 2010 10:18 am
First name: Jim
Last Name: Kirby
My kerfed linings have all been purchased, but I'm tending now towards laminated linings, or using the individual little blocks when needed for classical builds.
Jim Kirby
kirby@udel.edu
PostPosted: Thu May 06, 2010 11:31 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I make mine too. Three blades ganged together with spacers (.290" alum discs) and a sled like the one used to cut fret slots. I tape ten to twelve pieces together & go at it. In an easy few hours, I can make enough for ten or fifteen guitars.
If I was building one or two guitars a year, I buy 'em.
Nice thing about building your own is you can get them as flexible or as stiff as you want. And you can use better material than some suppliers use. (less breakage)
I'm thinking about solid linings too, these days. Next guitar, I'm gonna give 'em a try.
PostPosted: Thu May 06, 2010 12:54 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Us Canadians are a frugal bunch, it is said in Florida that Canadian tourists are like Catamaran sail boats, never tip.
So far I have used uncle Bob from RC kerf lining so I am the different Canadian, but some may think those of us in South western Ontario are not real Canadians anyhow.
Fred
Fred Tellier
PostPosted: Thu May 06, 2010 7:27 pm
First name: Darryl
Last Name: Young
State: AR
So who is doing the tutorial on solid and laminated linings? <smile>
PostPosted: Thu May 06, 2010 7:33 pm
ColinS had some pitures of his setup.
PostPosted: Fri May 07, 2010 1:47 am
I sometimes use solid, sometimes kerfed linings. I took some pictures when I made a bunch of kerfed, triangular ones yesterday. This is probably the most efficient method you can think of, but I get reasonably good results, and its no too tedious. I have made them from mahogany, birch, poplar, spruce, ash, whatever I happen to have, and they all seem to work fine. Here I’m slicing up some poplar.
The thin slats are then thicknessed on the drum sander
Here’s my kerfing jig. Its a table saw sled, with a nail that indexes in the kerfs. One of these days I’ll stack 3 or more saw blades with spacers between them on the arbour, that should speed this operation up considerably. BTW, I’m using a Freud Diablo thin kerf saw blade.
Sometimes I slice them into individual linings and tape these into a wide “boards” up before I cut the kerfs in them. Here I’m cutting the kerfs first...
...and doing the slicing after
The next step is cutting the triangular shape. I attach each strip with double stick tape to an angled jig that rides against the table saw fence, and cut away the waste.
Finally, with the lining still attached to the jig, I quickly sand it on the edge sander.
And since I’m in the mood, why not make a few?
So, that took a while, but at least now I should have enough linings for the current batch of 11 guitars. Whew!
PostPosted: Fri May 07, 2010 9:25 am
First name: Tom
Last Name: West
State: Nova Scotia
I think Daniel Minard has brought up the most important point of why folks would want to make their own linings,......CONTROL...of the wood ,size.shape,flex etc. Using either Arnt's or Todd's super method will give excellant linings with minimal work. Nice job folks.
Tom
Users browsing this forum: No registered users and 42 guests
