It is currently Sat Aug 09, 2025 12:11 am
PostPosted: Mon May 03, 2010 8:03 am
The newest Luthier Tips du Jour instructional video is on Youtube. The topic is Sharpening. Subtitles are available in both English and Portuguese and you can translate them into any other language by using the CC option on Youtube.
As always, comments and discussion are welcome.
Enjoy!
PostPosted: Mon May 03, 2010 8:48 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Another fine job, Robbie.
This makes me think of a question, how is the proper way to sharpen a curved chisel like these. I do them by hand but there must be a better way.
Fred
Fred Tellier
PostPosted: Mon May 03, 2010 10:31 am
Throw them away, they're bent! :D
PostPosted: Mon May 03, 2010 10:44 am
The pic of those chisels makes me think of the Picasso clock pic. haha If it doesn't fit in the honing jig then you just have to do the best you can which means by hand. With a little practice it is easily done.
PostPosted: Mon May 03, 2010 1:03 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I think you mean Salvador Dali clock pic ;)
Great video!
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Thu May 06, 2010 8:14 am
Thank you for the video.
Chuck
PostPosted: Thu May 06, 2010 8:46 am
Great video Robbie. I think I may graduate myself shortly from scary sharp to water stones. :)
I like that little angle setup stop too.
PostPosted: Thu May 06, 2010 12:59 pm
You are quite welcome Chuck and thank you Edward. Work sharp!
PostPosted: Thu May 06, 2010 3:25 pm
Filippo Morelli wrote:
Around 6:30, Robbie is sharpening the bevel. He suggests that you look and insure the complete face is being sharpened. This can be difficult at higher grits. One simple solution - take a permanent marker and place lines across the face, ensuring you get all the corners. The ink will dry in a moment. A few strokes on the stone, then take a look - you'll know exactly what Robbie is talking about.
Robbie,
at 7:50 you've hit the secondary bevel at 8,000. Don't you want to take a couple strokes at 8,000 on the back to remove any hook left from the sharpening?
Filippo
7:50 - yes, you could do that, or you could let the strop take care of it.
The marker tip is a good one.
In the video I show flattening the entire back of the tool. This is not really necessary unless you just like showing off the mirror finish on the back of your tools. You could just flatten the back of the tool near the tip. It is a lot less work.
PostPosted: Sun May 09, 2010 1:35 pm
First name: Hugh
City: Lake Oswego
State: oregon
In shining the back there is something there about 'til your arm falls off.' How does that normally translate to minutes?
Hugh
PostPosted: Sun May 09, 2010 7:03 pm
Hugh
For a high dollar chisel it goes fairly quick, perhaps 15 minutes or so if you know what you are doing. For a cheap chisel it could literally be until your arm falls off.
PostPosted: Mon May 10, 2010 6:07 pm
First name: Peter
Country: England
What chisels do you personally use? I have a set which are probably mid-range but I would like to get 1 or two top quality chisels for the more intricate things. The issue we have is every maker uses the name Marples, which used to represent quality, now every Tom, Dick and Harry uses the name and you can end up with awful chisels pfft .
I can get a pretty good polish on the blades, but to get what you have, I have had to have my arms re-attached several times now, but hey, I must have put at least 2" on my bicep laughing6-hehe .
PostPosted: Mon May 10, 2010 6:10 pm
I have used several kinds over the years. The ones you see in the video are Lie Nielson
PostPosted: Mon May 10, 2010 7:34 pm
Last Name: Livermore
State: Minnesota
Robbie,
Another great demo.
Thanks.
One thing that we rarely have an opportunity to discuss or experience is a qualifier or standardization of just how sharp, sharp is. I had carved braces and done all the other work necessary to close my first box up with the sharpest tool I'd EVER worked with. It was great. Then, while trimming the overhang a woodworker friend took my chisel and actually sharpened it. When he handed it back to me, I put it to the overhanging edge of the back and pushed on it in a manner I was familliar with and put that blade all the way through the material and into the side of the instrument.
It convinced me that I needed to learn how to sharpen tools, which is very close to the method you demonstrated. I do use the strop often to keep the edge and don't find a need to go through all the steps you demonstrated other than when I drop one on the concrete floor or buy a new one.
I believe many newcomers and some veterans alike have never experienced a truly sharp edge on their blades.
So professor, when you come up with a qualifier better than 'shaves the back of your hand' and less technical than 'no bigger than a 2 micron edge' Please let us know.
Until then, keep up the GREAT work!
PostPosted: Mon May 10, 2010 8:37 pm
Dave Livermore wrote:
Robbie,
Another great demo.
Thanks.
Dave,
Thank you for the compliment.
I think you are correct. Most folks don't know what a sharp chisel is. Hopefully my video will help a few folks find out.
Yes, you do not need to go through all those steps everytime you sharpen. Once you get the back flat it is pretty easy to keep the bevel tuned by using the 4000 or 8000 grit stones and the strop.
Users browsing this forum: No registered users and 42 guests
