It is currently Sat Aug 09, 2025 6:31 am
PostPosted: Thu Apr 29, 2010 10:51 am
First name: Blain
City: Leander
I've never heard of anyone using go-bars to glue a bridge, but it seems like it would make things easy as long as it is suitable for the job.
Just put some alignment bridge pins in and glue it up. Seems cleaning up squeeze out would be a breeze too.
Is anyone doing this already?
Any good results?
Any reason why this should not be done?
Blain
http://www.ullrichguitar.com
PostPosted: Thu Apr 29, 2010 11:11 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
If you were going to do this, you would have to support the top to prevent it distorting under the pressure of the go-bars. Tempting, but I wouldn't risk it. Vacuum or deep C clamps are the way to go IMO.
I use the Stew-Mac clamps & like to get five (or more) of them in place for even clamping pressure.
Seems excessive, but I have had a few bridges lift & this method has cured the problem.
PostPosted: Thu Apr 29, 2010 11:22 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
That sounds like a disaster waiting to happen, top damage potential is high.
Fred
Fred Tellier
PostPosted: Thu Apr 29, 2010 12:08 pm
First name: Tom
Last Name: West
State: Nova Scotia
Charlie Fox type clamp,very simple,easy clean up,self aligning,works like a charm. Easy to make yourself.
Tom
PostPosted: Thu Apr 29, 2010 12:15 pm
Did it on 2 guitars.
You need alignment pins, a bridge caul and jacks on the inside of the guitar to assure that the top doesn't distort. After 7 years, the bridges are still intact and the top is undistorted. The clamps and procedure touted by those above is more reliable and easier.
PostPosted: Thu Apr 29, 2010 12:19 pm
Last Name: Abercrombie
Daniel is correct.
Organizing a good support inside a soundbox is not always easy- it does help if you think about it before you close up the box. Once you have that worked out, there is no reason why go-bars could not do a good job for bridge gluing.
Clamping bridges 'from the outside' is nothing new.
Robert Bouchet (famous French maker of classical guitars) was known for his original jigs and fixtures.
Bridge gluing was no exception. From his (very interesting) 'Cahier d'Atelier' (workshop notebook) the following pictures give a good idea of his bridge gluing setup.
PS- You have to buy that 'Cahier'- it isn't online - I looked!
PostPosted: Thu Apr 29, 2010 1:12 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I'm with Fred -
I have visions of imploded tops - all that pressure on the center of the top. wow7-eyes . Clamps with cawls just work too well to go a different route.
PostPosted: Thu Apr 29, 2010 2:18 pm
Corky Long wrote:
I have visions of imploded tops - all that pressure on the center of the top. . Clamps with cawls just work too well to go a different route.
If your guitar top will implode, even with support from the inside, it will probably have difficulty handling the torque from several deep clamps twisting the bridge as you glue it. I notice that stewmac has 'levelling screws' to try to address this problem with their clamps. So, every method has its problems.
Clamps and cauls do work OK, once you work out the caul for the inside (which, BTW in steel string guitars, never seem to support the bridge wings beyond the bridge plate), and the padding around the soundhole, and getting 3 clamps organized in the space available. You do want to have the bridge pinned in place, since the clamps try quite hard to torque it out of position.
The question about how much clamping force should be required for a well-fitted bridge is another question entirely. Bouchet may well have been concerned about preserving/creating top doming with his method.
PostPosted: Thu Apr 29, 2010 2:21 pm
I did it on a number of instruments , before moving to vacuum clamping.
You do need to prop the top under the bridge but this can be as simple as a couple of just slightly overlength posts.
The back of the guitar should be sitting on the radius dish.
You need a guard for the soundboard cut out just bigger than the bridge and split down the centre(so you can pull it apart for glue squeezout cleanup)
Flat cauls on the thin bridge wings, rather than just a central go bar cause this area can cup
Don't load it up with all the go bars you can fit
It works fine, but I am glad I have gone to vacuum
PostPosted: Thu Apr 29, 2010 3:01 pm
Jeff-
I've done a couple with vacuum.
What glue are you using and how do you organize the cleanup of squeezeout? That was a problem for me- perhaps I should have waxed the top/bridge to prevent the glue sticking?
Also, for those considering vacuum-clamping bridges- I had the vacuum mess up a fresh FP finish on one guitar. I discussed this with Bob Garrish and we concluded that the vacuum was either pulling air through the Englemann top, or pulling oil/solvent out of the incompletely 'cured' FP. A word to the wise about being impatient!
PostPosted: Thu Apr 29, 2010 3:28 pm
Hot Hide Glue,
Ran the vacuum for about 10 minutes, then cleaned up squeezout then another 10 minutes.
PostPosted: Thu Apr 29, 2010 3:29 pm
First name: Blain
City: Leander
Thanks for the replies.
I'll get some supports for the inside and give this a try. It just seems like it will be much quicker to get everything set in place and still be able to clean up squeeze out easily.
Blain
PostPosted: Fri Apr 30, 2010 5:38 am
Online
I'm just imagining a go-bar slipping and spearing the top. wow7-eyes
I use 6" F clamps near the screw travel limits and/or wooden clamps with spacers over a deep caul shaped to the bridge shape to give enough clearance for cleaning glue squeeze out.
PostPosted: Fri Apr 30, 2010 8:49 am
I am puzzled by the "why?".
As others have noted, Murphy's law will dictate that at one time, maybe distant, maybe not, a go-bar will slip, or break, or bend the wrong way and ruin your top. Other things may go wrong, like the inside cauls cracking the back for example.
There are so many other sensible methods of gluing the bridge.
Bouchet's method is an "modern" adaptation of the Spanish method of using rope and wedges. At least with wedges or clamps one can control the down pressure, not so much with go-bars.
I agree that the "Cahiers d'atelier" is a must read, at least for those attracted by the high craftsmanship/low-tech realm. To boot, the drawings are a hoot.
What's wrong with making a bridgeplate caul riding the braces and using deep C-clamps or cam clamps?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Apr 30, 2010 9:53 am
Here is a discussion from when I ask the same thing.
viewtopic.php?f=10101&t=22088&hilit=Gobars+for+gluing+on+bridge
I ended up using a vacuum clamp I made. I made one vacuum clamp to place the pinless bridge and put some staple pins in the top and pressed the bridge down over the pins then removed the locating clamp and glued the bridge down with the vacuum clamp and the pins prevented the bridge from sliding.
PostPosted: Fri Apr 30, 2010 10:18 am
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.lmii.com/CartTwo/thirdproduc ... dge+Clamps
This thing is SO easy to use, no potential to damage the top, makes for cleaning squeeze out a snap. Remember to use thin wood scraps for the pressure bolts to bear down on. It even worked great on my harp bridge.
PostPosted: Fri Apr 30, 2010 10:48 am
Won't work on pinless bridges or access through F holes though. But other then that it's fine.
PostPosted: Fri Apr 30, 2010 3:18 pm
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
We used go bars(much larger size) to glue bridges down on harpsichords in Colonial Williamsburg. One time,my 2 journeymen and I were applying go bars to the bridge of a large harpsichord,and one of the guys slipped and broke a hole through the soundboard. That pretty well ruined it !!!
PostPosted: Sat May 01, 2010 12:37 pm
Last Name: Speller
City: Rodney
sounds like gluing on a bridge with go sticks has been done but i don't think i would ever do it. on a nearly finished instrument one of those sticks pops loose and its going to do some damage.
PostPosted: Sat May 01, 2010 1:29 pm
I would think that it wouldn't hurt to protect the top around the bridge and to remember that you don't need all that much pressure. The lining is clamped with close pins and how much pressure is that? The bridge is pretty much held down by the strings except for a pinless bridge. I had a guitar in for repair and it looked like the bridge was beginning to lift at the back and it was completely unglued which I found out when I doffed the strings.
I think it's another choice to have and not one to be dismissed. Heck, I think you could just put some CA on it and just lay some lead shot filled bean bags on it if you wanted too.
In answer to the topic question. Yes, there are people using gobars to glue on bridges. Just be aware of the caveats involved with doing it.
I agree-it can be done, but I have enough mishaps with go-bar sticks that I wouldn't try it myself.
Really- if you need a lot of clamping pressure in a normal bridge gluing situation, probably there is a problem with the fit/radius of the bridge.
A technique I don't see mentioned often, which does work if the bridge is properly fitted, is to use some good-sized rare earth magnets (in pairs) - under the soundboard and on top of the bridge. (another 'trick' from Sergei deJonge's building course....)
PostPosted: Sun May 02, 2010 8:01 am
I have some 1" X 1" X 1/4" neo magnets I use for clamping things at times and they can give your fingers a nice bite if you aren't careful too. :)
PostPosted: Sun May 02, 2010 8:52 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I really like the big note in red in the bouchet' notes: NE PAS COLLER À L'ENVERS (Don't glue wrong way)
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sun May 02, 2010 12:44 pm
Ti-Roux wrote:
I really like the big note in red in the Bouchet' notes: NE PAS COLLER À L'ENVERS (Don't glue wrong way)
Yeah, I liked that as well!! :lol: I guess that even Bouchet could make a 'stupid mistake' on occasion!
It's a very interesting book- we should try to put together a 'group effort' of bilingual folks (and semi-bilingual , in my case) to produce an 'unofficial English translation' of the 'Cahier' notes. The drawings tell a lot, but the written notes are very interesting and informative. It takes a while to get used to his handwriting, the Euro way of writing 1's and 7's, etc. but it's worth it. Too bad the book is so $$ to buy (about $70 Cdn with shipping from Fr.)
PostPosted: Mon May 03, 2010 8:13 am
I have used gobars on three guitars to glue on the bridge. The bridge has to fit nicely to the top in a dry fit. And you need cauls on both the back and top with adjustable columns ( for me small turnbuckles). Then seat the guitar back in your sanding dish. And your ready to go. I position the bridge and then use yellow glue to glue tiny blocks to keep the bridge in position. In half a minute, your hot hide glue is on and you're done. Incidentally, in my assembly room ( just my fancy name for a small untidy humidity controlled room ) I use the ceiling for the top of my go bar deck. Great visibility. Using birch go bars!
Under Compensated Nut!
Users browsing this forum: Colin North and 45 guests
