It is currently Fri Aug 08, 2025 6:57 am
PostPosted: Mon Mar 22, 2010 2:54 pm
State: ON
Is there any company out there that is making a stock case for a 12-fret dread? I haven't had much luck finding one here in Canada. I'm also looking for one that doesn't say Martin on it.
Thanks for the help
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Mar 22, 2010 3:25 pm
State: ON
Thanks Todd, I'm not sure why I didn't think of that myself.
Josh
Josh House
PostPosted: Mon Mar 22, 2010 4:54 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
It depends on the dimensions of the 12 fretter. Unless the cases have changed in the last couple years a modern Martin 12 fret D (D18VS, HD28VS) will fit in a "normal" TKL dread case. An older Martin 12 fretter (my 1973 D18S) won't fit.
PostPosted: Mon Mar 22, 2010 5:37 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Hi Josh
I just looked at my D size case the double arch style the Gary Gauger has at Heinl and it looks like a round shoulder 12 fret D might fit. If I had a 12 fret D template I would check for you, Gary told me a 12 fret 000 would fit in the 000/OM case he has and I tried it on one I had here and he was right but it was a little tight on the 12 fret body I was building but did fit in and a finished body would probably slip in easier.
Fred
Fred Tellier
PostPosted: Tue Mar 23, 2010 7:44 am
State: ON
Hi guys, Thanks for the help. The shape I'm building is a Gibson slope shoulder.
Fred, I buy almost all my cases from Gary. The the body fits fine in one of the dread cases he stocks, the problem is the neck length. I built a 13-fret dread a couple months ago and it wasn't a great fit due to the slightly shorter neck. I'm sure a 12-fret neck would not fit that case at all.
Todd, I'll give the Geib style case from Elderly a try.
Josh
Josh House
