It is currently Sat Apr 25, 2026 9:13 pm
 Post subject: New Walnut Uke
PostPosted: Sat Mar 13, 2010 5:31 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Here's my latest build....a walnut concert ukulele. Based off the Martin style plans from Elderly
All walnut body, mahogany neck, wipe-on poly finish. It sounds really sweet so far!!
Has anyone used wipe-on poly on rosewood? The finish went on great except for the rosewood veneer. It didn't seem to cure well, even after a few days. It wasn't sticky, but soft and easy to fingerprint. I ended up scraping it off and using shellac on the headstock.
 Post subject: Re: New Walnut Uke
PostPosted: Sat Mar 13, 2010 5:38 pm
First name: jack
Nice looking uke ;
I really like the rope styled purfling,
jack
PostPosted: Sat Mar 13, 2010 6:02 pm
Very fine uke! [clap]
And rope on ukes just seems perfect. Walnut is a nice change from mahogany.
You say you got the plans at Elderly?
Joe
PostPosted: Sat Mar 13, 2010 7:20 pm
I like it a lot. Very nice work.
PostPosted: Sat Mar 13, 2010 8:14 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Much prettier than the walnut uke I've got in the works at the moment!
PostPosted: Sat Mar 13, 2010 8:43 pm
City: winnipeg
State: manitoba
Country: canada
Quine:
Nice job!
How is the action? The saddle looks a tad high but if the action is right , its right.
Bob
PostPosted: Sat Mar 13, 2010 8:45 pm
Last Name: Shaw
City: Philadelphia
Wow! Make me want to build a uke now...mike
PostPosted: Mon Mar 15, 2010 12:41 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
unkabob wrote:
Quine:
Nice job!
Bob
Thanks Unkabob. The action is a bit high now. I plan to drop it some and do the final adjustments to the saddle. I also have to shorten the strings some....almost ran out of tuner capstain. Man these nylon strings can stretch!!
I just got to the point where I wanted to string it and play it for a while!! bliss
PostPosted: Mon Mar 15, 2010 1:39 pm
City: winnipeg
State: manitoba
Country: canada
Quine:
That rope purfling is to die for.
A truly fine piece of work.
Bob
PostPosted: Mon Mar 15, 2010 1:55 pm
First name: Tom
Last Name: Dowey
City: Sudbury
State: Massachusetts
Zip/Postal Code: 01776
Very nice looking uke. I am always curious on how the neck is attached on uke's? How do you attach yours? Thanks in advance.
PostPosted: Mon Mar 15, 2010 2:08 pm
Quine,
This is a very nice looking ukulele. I really like the rope binding and purfling. Did you make the rope? If not where did you get it looks perfect on the ukulele. Yes, it does look like pretty high action.
Great Job! [:Y:]
Philip
aka konacat
PostPosted: Mon Mar 15, 2010 2:29 pm
Nice looking uke.
As you mentioned, polyurethane doesn't dry too well over rosewood. I found that it helps to do a couple of coats of shellac prior to the urethane.
PostPosted: Tue Mar 16, 2010 12:32 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Thanks Philip. I didn't make the rope this time. I got it from LMI
Tom...I used a mortise/tennon joint for the neck. I figured the hole was too small for a bolt on
PostPosted: Tue Mar 16, 2010 3:29 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
Just got back from Hawaii yesterday and was thinking I need to build an Ukelele. Saw some nice ones in a store in the Sheraton.
This one and hearing Bruddah Iz for the last several days just reinforces it. Beautiful Uke.
Darrin
PostPosted: Tue Mar 16, 2010 5:11 pm
Great looking Uke. I've just started a Koa Baritone Uke for my uncle.
Rob
PostPosted: Tue Mar 16, 2010 5:53 pm
First name: Phil
Last Name: Lidov
State: CO
Joe
I'd also be interested to know how you liked the plans. I'm finishing a second guitar right now through the Colorado School of Lutherie (http://www.evd303.com/school.php) with Edward Dick. I was thinking that a concert Uke would be a great project to try on my own. I've been looking around for a plan to start with.
Phil
PostPosted: Tue Mar 16, 2010 7:17 pm
Quine,
I think I will use your ukulele as an example for a future build. The look is classic and stylish.
I also wanted to let you know about the current Luthier sale going on at Hibdon Hardwoods. They have Mahogany sets and wood for necks that have some issues but are really inexpensive. It is likely that the ukulele template will clear the wood better than a guitar template. Since you and Hibdon are in the same town I would think you can pick the woods yourself. Also, on the next ukulele build you might try a pass through pinless bridge instead of the tie bridge. This is very popular in the ukulele community. Check out this thread that has photos from Dave White. It really makes a clean looking intrument.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=22416&p=308356&hilit=bridge#p308356
PhilL,
If you are checking out plans you might try the following two locations. Hana Lima ‘Ia has a variety of plans including Kasha braced plans. Another site to try is Bob Gleason’s Pegasus Guitars and Ukulele.
http://www.hanalima.com/
http://www.pegasusguitars.com/
Philip
aka konacat
PostPosted: Wed Mar 17, 2010 12:39 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Hey Phil
Here's a link to the plans.... http://elderly.com/books/items/113-45.htm
Its a good set of blueprints with a few options on construction....even a pineapple body shape. I used the standard 2 tonebar style.
Users browsing this forum: Facebook [Bot] and 44 guests
