It is currently Fri Aug 08, 2025 5:55 am
 Post subject: What is this tool ?
PostPosted: Thu Mar 04, 2010 8:20 am
Last Name: A
Hi -
I saw this in the Romanillos video posted by Guitar Gourmet -
what is this tool ? Looks like he is marking the soundboard for the rosette with it. The next scene he is chiseling out the space betweens the lines he marked.
Is this tool available to buy somewhere ?
thanks
john
 Post subject: Re: What is this tool ?
PostPosted: Thu Mar 04, 2010 8:31 am
This is a link to the equivalent tool offered by LMI:
http://www.lmii.com/CartTwo/thirdproducts.asp?NameProdHeader=Rosette/Circle+Cutter
Pete
PostPosted: Thu Mar 04, 2010 10:11 am
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
hi
you can make one easily from a carpenters marking guage
PostPosted: Thu Mar 04, 2010 10:21 am
They are easy to make from scrap wood, a number of us here have built them. This one is BRW and cherry.
PostPosted: Thu Mar 04, 2010 2:58 pm
I built this one out of white oak. It is a bit rough - but it works pretty well, still. I also use it to "route" (with help of a chisel) all my binding and purf chanels on the body.
PostPosted: Thu Mar 04, 2010 5:34 pm
I was just thinking to make something similar for cutting plastic pickguards for the soundhole bit. You just gave me two other uses for it,
3 in 1 so far. This is my kind of tool! bliss.
Good timing guys. [:Y:]
PostPosted: Thu Mar 04, 2010 6:00 pm
Beautiful!
PostPosted: Fri Mar 05, 2010 3:36 pm
Colin,
Yeah it works pretty well. I saw a picture of it in Guitar Maker's Workshop - or some other similar book at Barnes and Noble. I use it for everything - cutting rosette channels, rosette materials, binding channels, purf channels, marking gauge, etc. and probably in the future for pickgaurd material too.
I need to remake it with a bit more care and I think I would not use big, dumb metal screws this time. I also really like the idea of using a metal rod/dowel for the pivot like that beautiful Brazilian one above. These things make great beginner projects to hone hand tool skills and an eye for detail.
PostPosted: Sat Mar 06, 2010 6:57 am
justink wrote:
Colin,
Yes (Justin?),
I have the Workshop book, must have a look.
It would be good if I had some offcuts of nice woods to use for tools and jigs, but every piece I have is tonewood in guitar sized pieces, and all jigs etc I have made are first/second time builds to tryout, mostly birch ply, lumber and MDF.
Got to keep an eye out for some old, scratched solid hardwood furniture going cheap, to cut up. :roll:
PostPosted: Sat Mar 06, 2010 11:08 am
First name: David
Last Name: LaPlante
I use the LMI cutter pictured above which works well though it's awkward to adjust the radius as well as the cut depth......hard to see the blade too when you are using it..
These all work best when you make the cuts in four separate arcs following the grain of the top. Cutting against the grain may result in a ragged edge.
i.e.-with 3 and 9 o'clock being along the center line swing your cuts;
9 o'clock to 12
3 o'clock to 12
9 0'clock to 6
3 0'clock to 6
make the cuts shallow at first progressing to the full depth set of the blade. Too deep too fast and you can "plow" the grain with the blade (make sure it's really sharp).
I use a Stew Mac rosette jig and dremel to remove the bulk of the material to depth keeping clear of the cuts and finish up with and exacto blade to remove the last little web between.
oh yes, and make sure the bevel on the blade is set on the waste side with the flat side against the finished cut.
Users browsing this forum: ChuckB, Ken Lewis and 32 guests
