It is currently Thu Aug 07, 2025 11:59 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 24, 2010 10:58 am
Hesh wrote:
What Mike said about CF rods in the neck - does nothing to belay body distortion.
But... combine the CF rods in the neck with say what Dennis just posted, using CF rods to maintain the body geometry and you just may not ever need a neck reset...
Pretty cool Dennis!
Exactly! There are tons of things you can do to delay the effect of stress but short of eliminating the strings the loading, stress will slowly but surly take its toll. Even Carbon fiber rods will eventually yield to the stress. We probably wont be around but it will happen :D Eat Drink
PostPosted: Wed Feb 24, 2010 11:08 am
Frank Cousins wrote:
Newbie thought... Is a guitar purely a musical tool with a limited life or are folk building heirlooms that last forever...I guess the ideal is both, but given that the tone is so affected by the rigidity or otherwise, is there a dnager that in the course of looking for ultimate stability and maximising the life of an instrument, it compromises the very thing its designed for?
Yes there is that is the reason we still search for the Holy Gail of structure vs responce centuries after the invention of the guitar.
PostPosted: Wed Feb 24, 2010 11:46 am
Conventional construction and proper care on a 6 steel string light gauge I would say that with proper care 20 years is reasonable mean time. There is far too much that is dependent on the individual build to really define a good number.
PostPosted: Wed Feb 24, 2010 11:55 am
Filippo Morelli wrote:
True. And I realized you have tongue and cheek icons at the end of the sentence. But I think it is feasible to take the OP's question in some reasonable context. From this thread I'm convinced that conventionally built guitars fall under the, "yes" category. I'm unconvinced that some of these alternate designs fall in that category.
Filippo
I under stood this but the point I was making was that while there are many things we can do to delay the affect of load stress we should never consider that we have eliminated the affect of load stress. Buttressing and other reinforcement redirect the load to another bearing surface. That surface and or the buttress will at some point deflect under the constant force of the load stress. It is easy for us to think we have eliminated the stress but all we really do is redirect it or reinforce against it but we never eliminate it. To me that is an important thing to always keep in mind
PostPosted: Wed Feb 24, 2010 12:19 pm
Michael,
Good point.
To this end, I looked at a 1940's 0-15 Martin last night, in for repair at Greenridge. When we started taking measurements and inspection, it was clear that there was compromise in the dome behind the bridge. It was not a bridge/belly problem. When checking the dome, it was high but acceptable from center to edge. What was interesting ... as you moved the straight edge from heel block to bridge, the dome was asymmetrical to the base side. The treble side was dead flat. So bracing seem to have "let go", even though they were affixed.
Material stress is inevitable. Ultimately we are distributing the stress. But to that end, I would also point out that we build guitars like we build unibody construction automobiles. This is cost effective in manufacturing. Race cars are not built that way, on the other hand. One could build a frame with a sound box around it, but that's not how we build guitars. The net result would be a very different stress distribution. The counterpoint being - it's not the stress that string tension brings that is the issue. It is the stress it brings in respect to the structure that is being asked to deal with the stress.
Filippo
ab-so-lute-ly
PostPosted: Wed Feb 24, 2010 2:38 pm
;) Ok, good response... but I guess what I was asking is that do any builders somethimes look at this say from the musicians perspective that the instrument is a tool, and that there is a possibility of perhaps gaining something in tone, if prepared (and well heeled) enough to recognise it will have a finite (shorter) life? Replacing it when its starts to fail?
I love the romance in this craft, the wonderful ideal that even my cobbled together attempts will probably out live me in usefulness and for those who build remarkable instruments and are at the top of their game, the idea that these will be around in 50-70 years and sound even better is a wonderful thought... but is there a danger that it becomes the primary one for some?
PostPosted: Wed Feb 24, 2010 2:52 pm
Are you asking if would concider designing with the thought that I could build a superior sounding guitar but with a shorter life sand to achive this superior tone?
If that is the question, to me that is a strange inquiry since we are at a point where we build instruments at present that are capable of producing tonal characteristics superior that the human ear is capable of evaluating that will far out last the builder and or player. So my response is no I don’t look at it from that sand point. I look at guitar design in terms of what we know works in regard to structure integrity.
But maybe I miss understand your question.
PostPosted: Wed Feb 24, 2010 3:09 pm
Michael,
Good point.
Filippo
Filippo,
I've seen that on many old steel-string guitars, especially Martins, presumably due to the asymmetry in the the tone bar placement. Since the tone bars generally run close to the bridge plate on the treble side, and run diagonally toward the bass side, there is "loose" area of the top on the bass side that deforms more readily. We're talking bracing for right-handers, anyway. Ladder-braced guitars with symmetrical bracing seem to dome more symmetrically.
I'd agree that eventually, pretty much all conventionally built, non overbuilt guitars will need a reset. Old instruments I've seen that didn't need one yet show evidence that they're on their way to needing one someday.
PostPosted: Wed Feb 24, 2010 3:13 pm
Hi
No you understood the question correctly (although it was not addressed at anyone specifically), just a thought as to whether it was ever in anyones thoughts. I think it stemmed really from the issue of neck resets, in that methods have been devised and are in common use that make this process less invasive and easy to manage, than the traditional glued dovetail, and (arguably) have minimal impact on tone (although there are probably plenty who would argue that point ;) )
So are these methods used to facilitate easier resets in the future thus there being an acceptance that it will be inevitable, (or that it allows just a little lighter construction) or simpy because are they are easier/cheaper to do? or both ..
PostPosted: Wed Feb 24, 2010 3:19 pm
Hi
Well for one I use a bolt-on neck that the fretboard extentionas well as the neck is bolted. ther is not glue to soften and seperate. That makes a reset very simple and far less risky repair
PostPosted: Wed Feb 24, 2010 3:52 pm
Hi
I think (?) I may have seen a pic that you posted of this, (please correct me if my memory is totally off :shock: -its been known). Is it the one where there is an extension of the the neck under the fretboard jointed into the neck block?
Given that method, how would you assess the impact on tone over a conventional joint if any...?
PostPosted: Wed Feb 24, 2010 4:18 pm
Some what what you describe. On my neck assemblies there is a glued on maple 1 1/2" wide 2" lonng tenon on the bottom side of the fretboard in which two threaded inserts are added. There is a mortise in the top/neck block flange that this tenon sets in and bolt holes that match up to the threaded inserts in the tenon 2 #10 screws hold the extention and its tenon inplace aginst the bottom of mortise tightend forn inside the body assembly of course.
It adds a small amout of extra weght but that weight is not in the active part of the top and I have not had any real changae in tonal attributes other than the theoritical assumption that a heavier neck assembly adds sustain but that is for another debate.
Users browsing this forum: oval soundhole and 41 guests
