It is currently Fri Aug 08, 2025 2:00 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 03, 2010 10:44 am
I thought he was talking about two completely different problems in one post! :D
PostPosted: Wed Feb 03, 2010 11:36 am
Last Name: Cox
Todd, Thanks for the info.
Unfortunately, I have 2 outlets in the entire basement... and none anywhere near the saw. They are on the same circuit as the 3 light bulbs -- which is a 15A circuit with a standard breaker. If I want Lights, I can't run the saw.. and vice versa.
I am planning to run a couple 20A circuits and a 220V 30A or 50A circuit in my work shop area.... As well as installing a couple lights...
It's on the list of things to do...
PostPosted: Wed Feb 03, 2010 1:41 pm
Image Image
PostPosted: Wed Feb 03, 2010 2:06 pm
Last Name: Abercrombie
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Wed Feb 03, 2010 2:13 pm
truckjohn wrote:
In theory, the tension adjustment should be running off of a spring.. so it should be independent of just taking slack out of the blade... but it may not be.
You might check that the tension adjustment isn't changing when you have no blade in it... and also that the spring is properly adjusted (Not sure how to do this... but I would hope there is some way to make sure it doesn't have a bunch of slack in its aparatus that manifests as Tension on the indicator..)
Checking out what is really happening in the tensioner is a good idea.
My neighbour has an older 14" Chinese Delta knockoff bandsaw that he was given because 'it didn't work properly'. He found that he couldn't get it 'set-up' even with a new blade, and asked me for help.
After a bit of head-scratching, it turned out that the threaded adjustment shaft was hitting part of the tensioner, once it was 'screwed down' far enough to 'tension' a standard blade. Some work on the saw freed things up. The alternative was to use a shorter blade by 1" or so, but in this case he wanted the convenience of buying 'off the shelf' 93½ inch blades.
PostPosted: Wed Feb 03, 2010 5:01 pm
Thanks everyone.
Todd I really like this saw and once I understood that the tension gauge is not all that... I am ok. I tensioned the blade by feel last night and it works great but the needle on the gauge has to be on the 5/8" but no worries. Thanks for your help.
I took the blade off and laid it up next to the OEM blade and it's about an inch longer.... This explains what I am seeing on the gauge.
Chris I took your recommendation too and called Lou Itura this morning and had a nice long chat with him. Nice guy - very generous with his knowledge. I ordered a carbon steel 1/4" 6 TPI and a bimetal 1/4" 6TPI and of course his catalog too.
Howard I know how to use the blue ones but I am not familiar with the spring or where to put it...??? :D
Thanks again everyone and Howard.... :D
PostPosted: Wed Feb 03, 2010 5:10 pm
It's an either / or! The spring goes where the sun never shines! :D ;)
PostPosted: Wed Feb 03, 2010 5:57 pm
Hesh, do you remember the rationale for each blade? Why those two? I might be interested in ordering some, too, when money gets less tight.
PostPosted: Wed Feb 03, 2010 6:24 pm
James bro yes Lou recommended both of them saying that the carbon steel sounds fine for my limited use and the bi-metal blade he thought would last longer, IIRC partly because it can have more tension and this helps it cut better and wear longer. Don't quote me I was sitting in a car outside of the shop waiting to go in this morning while we spoke and the conversation was suffering from poor reception where I was.
Also part of the rational was that I told Lou that I just wanted to try a couple of different blades too to see what I like and them and I will order more of the winner. I don't go through blades very fast but this is likely to change going forward.
Thanks Waddy.... :o :D
PostPosted: Wed Feb 03, 2010 6:58 pm
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
Get the band saw book by Lonnie Bird. He says all bandsaw tension gauges on the saws are junk and if you set it to the next size up it will get you close.
PostPosted: Wed Feb 03, 2010 7:14 pm
[quote="Hesh"]Thanks everyone.
That's unacceptable! [xx(] I'd take it back for a refund.If it said 111" on the box , that's what you should get. ;)
PostPosted: Thu Feb 04, 2010 9:26 am
Thanks Filippo and I hear ya and agree. But I discovered that the blade that is responsible for my woes, the 1/4" 111" Olsen is actually 112" which explains why the tensioning gauge needs to be on "5/8th" in order to tension this one-off, out-of-spec blade. Everything works great I just have to ignore the gauge.... :?
So I really don't think that I have a Rikon problem, at least yet. When I receive the 2 new 1/4" blades that I ordered from Lou Itura yesterday and install one of those if the gauge is still dramatically off I may call Rikon then.
The universal opinion of everyone that I spoke to is that the gauges on saws are kind of like the infamous "check engine" dashboard indicator on Generous Motors cars - useless..... :D
I certainly thank you too for your offer to help out if I need to compare anything to your saw - many thanks!
PostPosted: Thu Feb 04, 2010 12:02 pm
Edward Taylor wrote:
How do you know when you have too much tension? Or is that a dumb question...
When the wheels heat up to about 40°C / 100°F it's too much - at least on my bandssaw (Inca 710). Blades will break prematurely and I think it's not good for the bandsaw either (bearings etc.)
P.S. To tension the blade I also "tune" it to a note that sounds o.k. to me (as described before by others).
PostPosted: Thu Feb 04, 2010 3:19 pm
Thanks, Hesh [:Y:]
PostPosted: Thu Feb 04, 2010 8:49 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Hesh,
There's nothing wrong with your saw, it's the blade length that is at fault. Since the pivot point for the
indicator needle and the tensioning scale are mounted on the saw frame, but the connecting pin to the
needle is mounted on the vertically sliding mechanism, the longer the blade is, the higher the needle points.
You can see that the 1/4" blade I've got on right now is reading "1/4", when in fact there is no tension at all
on the blade. You can adjust that out with the adjustment screw just above the needle pointer, but I pretty
much ignore it...I've got the Iturra tensioning gage, and it works well, but I do just as well tuning by a nice clear
note on the back length of the blade (so it's not hitting any guides while vibrating).
Gene
