It is currently Thu Aug 07, 2025 2:33 pm
PostPosted: Sun Jan 31, 2010 3:13 pm
Last Name: Sollod
What is the best way to cut out a sound port? ...a router? ...some kind of saw? I figured I could place a template of the shape that I want to use, draw out the shape on the side, and cut it out some way... I'm just not sure how I should do it...
www.swiftcreekguitars.com
PostPosted: Sun Jan 31, 2010 3:27 pm
My ports are generally round, and I use a Forstner bit, with a backing block on the inside. When I made a bigger oval one on a test mule I used a burr in the Dremel tool. It's easy to slip and mark up the side, so be careful. All's fair in love and lutherie.
PostPosted: Sun Jan 31, 2010 4:26 pm
Last Name: Sollod
Alan,
I was thinking an oval would be nice. I've seen several pictures of these posted. I have found that sometimes power tools can get away from you and it can be better to use manual tools. I could see how a fostner bit would work for a round sound hole. There must be different approaches that people take...
PostPosted: Sun Jan 31, 2010 4:29 pm
I think router.
Milton, ON
PostPosted: Sun Jan 31, 2010 4:34 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I rough mine out with a carbide inlay cutter using my Stewmac dremel router base, (works like a Rotozip saw) and final shape with files and sand paper. My 1st was round and done like Al's but to me it looked like the entrance to a bird house so I went to a oval shape on the next 2.
Fred
Fred Tellier
PostPosted: Sun Jan 31, 2010 4:37 pm
Draw the design, use a forstner bit to cut a few good size holes, Dremel on Stewmac base with fishtail bit to get close, then switch to a sanding drum on the Dremel to fine tune it. and get smooth.
PostPosted: Sun Jan 31, 2010 9:55 pm
Depends what shape you're doing. this saw will cut any shape however. Sanding sticks and files to finish. It doesn't work however unless you cut the hole before the top is glued on. I use it for archtop F holes as well. http://www.leevalley.com/wood/page.aspx ... at=1,42884
PostPosted: Sun Jan 31, 2010 10:00 pm
First name: Tracy
Last Name: Leveque
State: CO
I've done it several ways, but I think the safest way for a beginner would be to drill a few holes in the design, then use a small sander in your dremel to sneak up on the line. Once you get close enough, a small mill file, and any other file can be used to get to the final shape. Then use sandpaper to clean up. It may take longer, but much less stressful. This is done after the rims are bent and the linings and blocks are glued in. Good luck!
PostPosted: Sun Jan 31, 2010 10:13 pm
I've only done one but it was a complex shape. I used a laminate trimmer with a 1/8" bit but I wouldn't recommend it unless you're pretty comfortable with the tool. It would be easy to make a big mess.
First I made a paper pattern and glued it on.
Made the raw cut with the laminate trimmer.
Clean up and beveled with sandpaper on a stick.
Ebony and maple laminated backing.
These users thanked the author SteveSmith for the post: Glenn_Aycock (Wed May 27, 2015 7:07 am)
PostPosted: Mon Feb 01, 2010 5:53 am
I just use a round soundport, and have found that the easiest solution to me has been a hole saw.
PostPosted: Mon Feb 01, 2010 12:46 pm
I use a Dremel and a carbide "fishtail" bit, with a clear, smaller base that I made for this operation. Follow w/sanding drum on the Dremel, sanding sticks/handsanding to finish off. I leave my doublestick taped pattern on the guitar through the finishing.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
Users browsing this forum: J De Rocher, Jim Watts and 13 guests
