It is currently Wed Aug 06, 2025 11:14 pm
PostPosted: Tue Jan 19, 2010 10:30 am
First name: JASON
Last Name: ARRINGTON
City: WINTER HAVEN
State: FL
Zip/Postal Code: 33880
Country: UNITED STATES
Does anyone have experience building with carbon fiber or know where I can get some information on it.
PostPosted: Tue Jan 19, 2010 10:43 am
What info are you looking for? I have built large scale RC aircraft frames with carbon fiber and used carbon fiber round bar and square bar as stiffeners in some lutherie. I have not attempted a body from a CF matrix because I like wood :D That said most any CF distributer can answer just about any question you may have if one of us here can't. Just Google Carbon fiber distributor and you will find tons of useful links
PostPosted: Tue Jan 19, 2010 10:45 am
First name: Martin
Last Name: Lane
City: Grand Rapids
In this case, search can help you.
search.php
viewtopic.php?f=10101&t=25486
viewtopic.php?f=10101&t=25366
viewtopic.php?f=10101&t=25172
viewtopic.php?f=10101&t=24717
viewtopic.php?f=10117&t=23633
viewtopic.php?f=10101&t=23634
viewtopic.php?f=10101&t=22865
viewtopic.php?f=10101&t=22468
viewtopic.php?f=10123&t=21609
viewtopic.php?f=10101&t=21333
viewtopic.php?f=10101&t=21162
viewtopic.php?f=10101&t=21165
viewtopic.php?f=10101&t=21058
viewtopic.php?f=10101&t=20897
viewtopic.php?f=10101&t=20684
viewtopic.php?f=10101&t=20229
viewtopic.php?f=10101&t=18947
viewtopic.php?f=10101&t=18898
viewtopic.php?f=10101&t=18851
viewtopic.php?f=10101&t=18414
viewtopic.php?f=10101&t=17213
viewtopic.php?f=10101&t=17322
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Tue Jan 19, 2010 11:11 am
First name: JASON
City: WINTER HAVEN
State: FL
I have a few questions (Carbon Fiber)
1) If building a uni-body design (DOES THERE NEED TO BE EXTRA FIBER AT THE NECK JOINT).
2) CF has many directional patterns, can you use one pattern for a guitar or do I need to combine several to build a solid structure.
3) Most CF builders don't use a truss rod. As players and builders what do you think about having a truss rod or not having one in terms of action, not strength.
PostPosted: Tue Jan 19, 2010 11:29 am
So we are talking electric body/neck. How are you planing to joint the neck?
As far as the truss rod is concered even with CF neck regardless of the fiber matrix make-up the string tension will bull a bow. The apex of the bow will be approx at the pont half way between the the nut and the neck joint. so the trick is either to make the neck shaft strong enough to resist the bow to the point of desired relief or provide a means of controling the bow.
PostPosted: Tue Jan 19, 2010 1:31 pm
First name: JASON
City: WINTER HAVEN
State: FL
I want to make an acoustic guitar and I want to have the neck and body be one mold, that is how current CF builders do it. Most necks these companies make are hollow inside, with the fretboard being attached after the body/neck is molded together.
PostPosted: Tue Jan 19, 2010 1:43 pm
JB, it sounds like you're asking about building an all carbon fiber guitar, similar to Rainsong. Is that correct?
PostPosted: Tue Jan 19, 2010 1:46 pm
In that case I will tell you that you will need some mass and buttress bracing at the neck joint and bracing to prevent the tension on the neck for rotating towards the sound hole and deforming the top. A lot of loading calculations will need to be done to know how much mass is needed. This same reason is why the neck on a wood acoustic is supported by a relatively massive neck bloc that is tied into the rim and back and sides. Also the bracing of the back and top see this load and are designed to support this load. Just like on a wood acoustic this load is constant and over time will take a toll on the structure of the rim. With wood guitars the neck assembly is designed to be removed and rest as the guitar changes shape for this constant load. If you plan on making a neck that is integrally part of the body then you will not be able to do this and you must provide structure that will permanently over come this loading. Even with CF as the material I suspect you will have issues preventing the rotation of the neck and rim from the constant string tension without a neck block and buttress bracing.
Good luck with that.
PostPosted: Tue Jan 19, 2010 2:21 pm
First name: JASON
City: WINTER HAVEN
State: FL
Thanks for all your help Michael and yes I want to build a guitar similar to CA, Rainsong, Blackbird.
PostPosted: Tue Jan 19, 2010 2:33 pm
That will be an interesting project without a doubt. I have played a Rainsong several hours. It sounded nice in many respects but to my ear lacked over all tonal color. I keep playing a friend of mines' to see if I notice the tone changing with play-in and age. At this point I can't say I have. but of course that is subjective. I suspect much like a laminated top that the sound changes very little with play-in and age. but that is just a logic based assumption.
PostPosted: Tue Jan 19, 2010 3:22 pm
Michael Dale Payne wrote:
................It sounded nice in many respects but to my ear lacked over all tonal color.<snip>................
Interesting. I've heard the same thing said of CF violin bows.
PostPosted: Tue Jan 19, 2010 6:22 pm
JB, I would be interested to hear how it goes if you decide to do this.
I have been thinking about this a bit and bought some fiberglass materials to experiment with. There are some famous examples of mixing wood and composites that didn't go so well (Ovation, and Stratacoustic come to mind).
I think it would be nice to have at least two guitars. One would be a nice sounding delicate wood guitar for home or studio. The other would be a carbon fiber so you could have one to take on vacation or camping or to the beach.
PostPosted: Tue Jan 19, 2010 8:46 pm
I've also spent some time with a Rainsong and I must say it sounded better than I expected but I agree it is a bit 'dry' sounding to me, i.e. lacking tonal complexity. It would be a wonderful guitar for trips to the boonies, beach and so on. Perhaps a CF guitar carefully made by a luthier could sound better than the factory versions in much the same way that handmade wood guitars are often much better sounding than the factory equivalents. You might want to check out some of Nick Dolby's work for ideas; he usually hangs out at the MIMF.
PostPosted: Tue Jan 19, 2010 10:44 pm
Last Name: Abercrombie
Jason-
Have you done a lot of work with carbon fiber or other composites (fiberglass,kevlar, etc) before?
Carbon is pretty nasty stuff to work with, IMO. And it is quite expensive to boot.
Also, the resins that the commercial builders use may not be available to you or may be tricky to work with.
I'm not trying to discourage you, but I've done quite a bit of work with glass and epoxy, as well as a bit with Kevlar and CF as well, and there is certainly a 'learning curve' before you get comfortable with the materials, Up to that point most people tend to waste quite a bit of material.
Wood (for me) is a much,much nicer medium to work with.
If you already have a vacuum system and some of the other stuff you will need, that will be a help.
If you'd like to have a CF guitar, then buy one- it will be cheaper and you can 'test drive' the instrument.
If I were trying to build a CF composite guitar, I think the odds would be pretty slim that my first effort (or tenth, for that matter) would be as good as one from a factory.
If you want to build a CF guitar, then go for it!
Users browsing this forum: meddlingfool, timtam and 34 guests
