It is currently Wed Aug 06, 2025 6:19 pm
 Post subject: Oops neck fit.
PostPosted: Mon Jan 18, 2010 4:43 pm
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Well....I've stopped to ponder my dilemma over a dark beer.
Seems I have a dovetail neck (ON MY FIRST STEEL STRING BUILD)that NOW slips too far into the body....the neck is NOW about 1/32 below the top now and still needs a Teenie Tiny bit of adjustment. So...it will even drop further if I continue.
My guess is I need to glue a wood strip on each side of the neck joint and begin the process all over again......unless someone knows all about this type screw up and a solution that plum evades me at the moment.
Boo Boo Bailey
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
 Post subject: Re: Oops neck fit.
PostPosted: Mon Jan 18, 2010 5:43 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Don't fear using shims, but tack glue them only until it is right in case you take too much off the shim and need to start over with new shims. You can get mahogany veneer at most good lumberyards or Woodcraft, the nice thing with it is both side shims start the same thickness. That is a good way to get practice setting necks, my 1st couple guitars ended up with shims. Someone mentioned in a previous post he used a charcoal art pencil instead of chalk for neck fitting.
Fred
Fred Tellier
PostPosted: Mon Jan 18, 2010 7:04 pm
These business card blanks at Lee Valley work well for shims. Not sure what kind of wood they are but For $3.50, a pretty good deal.
http://www.leevalley.com/wood/page.aspx ... ,250,43217
PostPosted: Mon Jan 18, 2010 7:08 pm
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Thanks fellas.....
Only one beer....so Dog and I are back out to the shop.
Kent
PostPosted: Mon Jan 18, 2010 7:31 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Yep. I only made a few dovetail joints. I have yet to make one that didn't require some veneer shims glued on one side or the other, or both! Don't worry about it. Scrap veneer is your friend in a situation like this. Try a dry slip fit on one side or the other, or both. It ought to bring you a little "proud" or high of the top. Then re-file and re-fit. If you get low, repeat the process. You'll be okay.
Users browsing this forum: No registered users and 43 guests
