It is currently Sat Jun 13, 2026 8:01 am
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Jan 16, 2010 9:45 am
I save the clear plastic containers that pre-packaged cold cuts come in. These have a snap-on lid that stays on pretty well. I store all manner of small parts and tools that I want to keep together- like nut and saddle files, etc. I label them with a Sharpie, and stack them up. I probably have 20 of them by now. Really cheap organizational tool!
PostPosted: Sat Jan 16, 2010 10:11 am
First name: Big
Last Name: Jim
I use the plastic coffe cans with snap lids for same purpose . Makes a great place to store materials , I have one that has all my stewmac water based stain bottles in it.
PostPosted: Sat Jan 16, 2010 10:18 am
First name: Big
Last Name: Jim
windsurfer wrote:
Drywall compound as easy to dye pore filler
Dry Spackle for pore filling when french polishing
-jd
?? for lutherie ?? how does that work ??
PostPosted: Sat Jan 16, 2010 10:26 am
Pat Foster wrote:
Paper towels, razor blades, glitter.
Ok Pat, I'll bite..........glitter? :shock:
PostPosted: Sat Jan 16, 2010 10:38 am
Not Pat but glitter for that Chihuahua testing that Al does.... :D
James drywall compound does indeed work for pore filling. It can be easily dyed too to match the wood or contrast the wood. Robbie O'Brien mentions it in his classes and perhaps on his excellent DVDs. It's pretty cheap too when you consider that you can do 10 guitar for 1/10 of a penny... :lol:
I haven't used it so I don't know if it shrinks over time or any other issues that may be associated with it.
PostPosted: Sat Jan 16, 2010 11:31 am
Speaking of waxed paper which I use too in my shop here is an application for waxed paper that I just did and thought it worth a pic:
PostPosted: Sat Jan 16, 2010 11:40 am
First name: John "jd"
City: Santa Barbara
-jd
Powdered spackle can be used just like you would use pumice or rottenstone. it just takes a little longer to make a good slurry because it cuts slower.
drywall mud can be used when you have big deep pores in dark wood -where you might otherwise get grey spots using pumice (or spackle). compound is very easy to dye into a nice dark color. after getting the color you want, thin it down and rub into the wood. let dry thoughougly and sand level.
-jd
PostPosted: Sat Jan 16, 2010 11:52 am
First name: Big
Last Name: Jim
How does it hold up to the finishes ? How does it hold up under use ?
Is there a thread on this somewhere that i can read up on ? Does anyone else use these methods ?
Sounds interesting , and i have to say "as amature" a bit nuts ! laughing6-hehe
However I have learned one thing comming here , that even though I am accomplished wudwerkr , as a luthier , i know zip. idunno
PostPosted: Sat Jan 16, 2010 2:32 pm
A water filter to convert tap water to nearly demineralized water for my sharpening stones, hhg, and also for moistening the sides when bending them.
Plastic foil (0.01mm = 0.0004" thin) for some gluing jobs.
PostPosted: Sat Jan 16, 2010 5:24 pm
Hi Markus - I wanted to ask you if I should be using distilled water with my sharpening stones? You got me thinking from your great post here.
My apologies to the OP for the temp high-jack... :? :D
PostPosted: Sat Jan 16, 2010 7:03 pm
Hi Hesh,
Off Topic wrote:
Distilled (or demineralized => cheaper than distilled) water for water stones will never be wrong, but it isn't mandatory either. Where I live, tap water is really "chalky", it contains a lot of dissolved chalk. For example, if I will boil water for 3 minutes in a perfectly clean pot will turn pretty white inside (easy to clean, but just imagine that much dissolved minerals...) When water stones dry the dissolved chalk will cristalize inside the stone and never get out there. One bad day it may crack because there will not be more "spare space" for chalk... For me, pure tap water is an absolute no-go, but distilled or even demineralized water (the stuff you use to fill up your car battery) would easily multiply the costs of my water stones (aprox. 1.- $ per "sharpening day" ), so this filter we use here for our coffee machines etc. is a great money saver for me. But even distilled water would be cheaper than buying every few months a new sharpening stone set :lol: If you get your mineral water only bottled from the store and not like me from the tap I guess you can just use tap water - if it isn't contaminated with bacteria and/or chlorine. :mrgreen:
I hope Mr. Off Topic answered your question ;)
PostPosted: Sat Jan 16, 2010 8:05 pm
City: Lawrence
Zip/Postal Code: 66047
idunno
mnemotorsports wrote:
Dave Rickard wrote:
I almost hate to let you all know how cheap I am.
I use the bag that my cereal comes in for wax paper. :oops:
laughing6-hehe Thats funny but if your going to tell people your using the bags I would say it is because you want to save the environment. Now I am going to follow your lead and start saving bags, to save the enviroment. of course.
Thats ticket, Yep I'm doing it save the environment. Thanks Matt
PostPosted: Sun Jan 17, 2010 1:00 pm
City: Santa Barbara
Working with dry spackle powder is just like working with pumice, only slower. Because it slurries up faster and is cheap, I prefer to use pumice. However if something happened to my can of pumice, I would not hesitate to use spackle until the next time i went somewhere where I could buy more pumice (and with no woodworking stores locally, I that might be months).
As for using mud in deep pores, it also holds up fine. we have a table that was finished this way over a dozen years ago that gets keys thrown on it every day and the pore filling is still fine. I would recommend you do a test before committing to using this as the look does not quite have the clarity or chatoyance of other methods. I won't use epoxy due to my history in composite construction, but lately I find myself using an egg white slurry rather than using drywall mud to fill... but I also have not been usng dark deep pored woods. If I was using fumed oak dyed mud might just be my first choice.
-jd
PostPosted: Sun Jan 17, 2010 3:26 pm
Christoph wrote:
I just found out that those little household sponges actually have two uses:
1) The soft side is a nice tool to even out alcohol thinned Epoxy pore filler.
2) The rough side is ideal for getting rid of any shiny spots in the dried Z-Poxy. It leaves you with a very smooth silk-mat surface. I would say that the roughness is somewhere between 400 grit sandpaper and steelwool.
And a 10 pack will set you back around $ 1.00 :-)
Great thread.
With all due respect, I'd like to question the use of the rough side of a sponge pad to get rid of the shiny spots in dried Z-poxy. I'm not sure that this is actually doing anything. The shiny spots indicate pores that are not yet filled, i.e. the surface is not yet level. When you remove the shiny spots with something so flexible like the pad (or steel wool) you aren't leveling so what are you doing? I think basically you are leaving pits that have a dull surface.
Regards,
PostPosted: Sun Jan 17, 2010 3:59 pm
State: Hessen
Pat Hawley wrote:
Great thread.
Regards,
Great comment. [:Y:]
What I meant to describe were not spots or grooves, but larger areas that are 100% pore filled and still shiny. Of course it is not a grea idea to try to remove substantial material with something as soft as a sponge. That should be done with a sanding block...
So the sponge does work fine to get rid of the shine.
PostPosted: Sun Jan 17, 2010 5:32 pm
L. Presnall wrote:
Larry,
It's a new bling option for my French polish finish. :D
No, really, I use it for checking modes and frequencies on tops and backs.
PostPosted: Sun Jan 17, 2010 7:18 pm
Now, here we have our first Metallic French Polish finish! :D
PostPosted: Mon Jan 18, 2010 8:07 am
Waddy are you calling Pat a metal flake???? :o :D laughing6-hehe
PostPosted: Mon Jan 18, 2010 8:41 am
First name: Martin
Last Name: Lane
City: Grand Rapids
I have a set of nut files made out of lengths of guitar strings superglued onto popsicle sticks. :oops:
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Mon Jan 18, 2010 11:44 am
Martin very clever!!! [:Y:]
PostPosted: Mon Jan 18, 2010 3:25 pm
First name: Martin
Last Name: Lane
City: Grand Rapids
Idea was stolen from tdpri.com. While the strings do give you a groove in a bone nut EXACTLY right to fit your strings, it does take a while to get there. like, maybe 30-40 mins...
PostPosted: Mon Feb 01, 2010 8:50 pm
First name: Martin
Last Name: Lane
City: Grand Rapids
mmm, fresh batch of bracewood.
PostPosted: Tue Feb 02, 2010 1:39 am
First name: Blain
City: Leander
The only thing I see that I use that wasn't already mentioned (exactly) is a metal reusable coffee filter for filtering paint.
Credit to this I believe goes to Mike Doolin in his write up on using KTM-9.
Great thread. Interesting to see what everyone uses.
Blain
http://www.ullrichguitar.com
PostPosted: Tue Feb 02, 2010 2:42 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I don't spray finish any more, but when I did, the cool paint filter was a milk filter from the local feed store. Nothing else filtered as fine or as fast. The milk filters were so fine that I couldn't use them on pearl coats--they removed the pearl.
PostPosted: Tue Feb 02, 2010 6:50 am
Not really a household item, but I use my leather shears a lot in the shop, mostly for cutting purflings and veneers. Doesn't always work for along-the-grain cuts in wood veneer - depends on the wood. Anyway, if you've never used leather shears, get yourself a pair. They cut cleanly and easily through just about anything. You'll love 'em.
Todd Rose
Ithaca, NY
Users browsing this forum: Facebook [Bot] and 29 guests
