It is currently Tue Aug 05, 2025 5:41 pm
 Post subject: Fingerboard radius
PostPosted: Sat Jan 09, 2010 11:31 am
What is your preferred one on an acoustic?
 Post subject: Re: Fingerboard radius
PostPosted: Sat Jan 09, 2010 11:35 am
So far 16" although I would like to do a compound radius sometime.
PostPosted: Sat Jan 09, 2010 12:14 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I like 12" best. No problem with 14" or 16" but it seems a bit easier for my fat fingers to cover the board on a barre chord with 12".
Tim
PostPosted: Sat Jan 09, 2010 12:15 pm
I like 12. I did a 12 to 20 compound radius on my last one. I don't think you really "feel" the difference, but I've been able to set the action lower on it than any other guitar I've built, too low probably. Something like 070 on the bass and 045 on the treble. I'm wondering if that is due to the compound radius.
Bob
PostPosted: Sat Jan 09, 2010 12:47 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use a compound 12" to 16" unless the client wants something different. In my mind a compound radius could allow for lower action. The string spacing spreads as you go up the neck, so the radius should spread also. Again, that's the way it works in my mind. As always, in real life YMMV.
PostPosted: Sat Jan 09, 2010 2:38 pm
How do you guys go about doing your compound? Just transition with the blocks?
PostPosted: Sat Jan 09, 2010 2:57 pm
I did mine on my DIY CNC machine, also did a sanding caul. Never tried doing one by hand, but I would imagine that 2 or 3 different radius sanding blocks could get you there.
PostPosted: Sun Jan 10, 2010 4:10 pm
Last Name: Garrish
If you're going DIY on it then there are some neat jigs that'll do a compound radius. Mario used to use one, as well as some others, which had two pivots. I think I saw a commercial jig that got fed through a sander or somesuch.
Bob Garrish
PostPosted: Sun Jan 10, 2010 7:22 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Here's a picture of my (really simple) jig.
PostPosted: Sun Jan 10, 2010 8:17 pm
Woody that is very cool. I take it the inner piece has graduated slots as well?
PostPosted: Sun Jan 10, 2010 8:20 pm
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
I think luthiers cool tools has a plan for one that can do compound radiuses.
PostPosted: Mon Jan 11, 2010 11:20 pm
I level the fretboard with a .75" sanding block, working from the outside to the center, following the angle of the edge of the fretboard, coming straight in the center and angling back out to the far side. This gives a compound radius, the longer you go, the bigger the difference between the two ends....
Gabriel Regalbuto
Carlsbad, California
Freedom 35!
PostPosted: Tue Jan 12, 2010 5:45 am
First name: Peter
Last Name: Johnson
Country: Ceridigion, Wales
Does nobody use a Plane ! (or is that far too simple and easy) ;)
p.s. I don't use much pearl
PostPosted: Tue Jan 12, 2010 6:25 am
First name: Woodrow
Last Name: Brackett
City: Grover
I done my first 10 or so with a plane. I had inlays but didn't do them until it was radiused.
PostPosted: Tue Jan 12, 2010 11:26 am
First name: John "jd"
City: Santa Barbara
I use a plane. It allows me to quickly get very close to the desired result. Follow up with a couple of swipes with a block to assure everything is true.
Dots are added after radiusing and I use a block to sand them flush.
-jd
PostPosted: Tue Jan 12, 2010 11:34 am
Last Name: Hammond
Every time I try a plane it ends up tearing out chunks at one end or the other. What am I doin wrong?
The Biggest Little City, Nevada
www.hammondguitars.com
I love building guitars!
PostPosted: Tue Jan 12, 2010 12:49 pm
First name: Woodrow
Last Name: Brackett
City: Grover
You're taking too big a cut and/or your plane isn't sharp enough.
PostPosted: Tue Jan 12, 2010 2:25 pm
City: Santa Barbara
tear out should not be a problem with a well set up plane.
I do radius before I trim to length, so even if I did get tearout at the ends it would be trimmed away
-jd
Users browsing this forum: Chris Ide and 43 guests
