It is currently Tue Aug 05, 2025 11:28 am
PostPosted: Thu Jan 07, 2010 10:06 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Just curious how others who use them construct/notch lattice braces. Do you cut them by hand or use a jig? Pics would be great.
Richard
PostPosted: Thu Jan 07, 2010 10:26 am
I use a table saw and make the braces the same width as the kerf. That simplifies things a lot.
PostPosted: Thu Jan 07, 2010 10:55 am
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
Here's what I do:
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=23892&p=325447&hilit=lattice#p325447
PostPosted: Thu Jan 07, 2010 11:16 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Thanks that look pretty easy, I will have to give it a try. What a great thread, I can't believe I missed it
Richard
PostPosted: Fri Jan 08, 2010 12:07 am
First name: jeff
Last Name: parker
City: anchorage
State: ak
Zip/Postal Code: 99516
This is my jig. I made a 10 degree angle block for my fretboard slotting jig. I use a dado blade I cut a slot in the angle block then moved it to the right the amount I wanted the spacing to be on the lattice and put in a piece of square metal. In my case it is 1/4 inch. Then I fixed the angle block to the sled. To cut braces you just put a board on the angle block adjust the depth to one half the thickness of your stock. You make one cut, then slide the stock to the right so the slot sits on the metal alignment. Then make another cut and so on until you have made enough slots. Then I cut the baces off the board with a band saw or a model maker table saw with a jewelers blade. Usually you can rip them close to the correct thickness or you could run them through the sander.
Users browsing this forum: Freeman, guitarjtb and 45 guests
