I dont have a pic, but will describe best I can ....
I bought a 4x8 sheet of 3/4 ply, and figured out the biggest box i could get out of it - at least I think it came out of one sheet .. anyway its 36x28x21 ...
on the narrow side - 21, at the top, I cut out three inlets, all blast gated - this where I select which hose - no Y connectors at all. The 2hp motor/impeller sits on its side on the box top, sucking up, and blowing sideways into a short 6 inch duct to the bag/filter. The separator/baffle drops down inside, from the top, full width and about a foot down, and about a foot inside from where the inlets are. The motor intake is directly behind this baffle, such that as material comes in, it will hit the baffle, drop down, and the air continues around to the impeller. All the insides are sealed with caulking.
I got the idea years ago from a FWW or such, and must admit, it works amazingly well .. I only get the finest of dust in the bag - no chips ever. I added two cleanouts .. one on the front of the box at the bottom, with threaded lock knobs, big enough to get a dust pan in for cleanout, and another on the side behind the baffle, to clear the impeller intake if required - amazing how many pieces of parchment paper or plastic bags get in there and need to be pulled out. As well, I added a plexi window on the front to see when its getting full ... but you will notice the suction start to drop as it gets close to the bottom of the baffle anyway. Before the post motor bag gets even half full, I will have to empty the box out many times.
_________________ Tony Karol www.karol-guitars.com "let my passion .. fulfill yours"
