It is currently Wed Aug 06, 2025 3:34 am
PostPosted: Mon Dec 21, 2009 9:22 am
Hi Guys
I've just put an LMI self adhesive clear pickguard on my latest build.
It didn't go on too well and I've got some small bubbles in it.
I'm a bit nervous about peeling it off. The finish is EM6000.
Would 'Acetone' be ok to use on the EM6000 when removing the pickguard?
Many thanks
Mat
PostPosted: Mon Dec 21, 2009 9:32 am
Matt,
Start with a hair dryer to soften the adhesive and peel the pickgaurd off. Mineral spirits will remove the adhesive from the finish.
PostPosted: Mon Dec 21, 2009 9:37 am
Thanks Steve [:Y:]
PostPosted: Mon Dec 21, 2009 10:50 am
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
I had to do the exact same thing on an earlier build which was finished with KTM9. I heated up the edge of the golpeador with a hair dryer and slowlyl pulled same off while heating same. I used goop be gone adhesive remover to get the adhesive off. That was more work than peeling off the plastic.
John Nowicki
Users browsing this forum: No registered users and 48 guests
cron
