It is currently Thu Jul 31, 2025 10:54 am
 Post subject: bent top armrest bevel
PostPosted: Sun Dec 20, 2009 2:14 pm
Hi folks,
Does anyone of you ever made a bent top armrest?
I know that neopolitan mandolin top are sawn and bent on a hot rod.
Any infos and picts are welcome.
regards,
Cédric Verglas
PostPosted: Sun Dec 20, 2009 4:51 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I was wondering about that also, I played one of Sheldon Schwartz bent top bevels and it feels real good, and to my eye it looks nicer than a bevel that is part of the binding.
Fred
Fred Tellier
PostPosted: Sun Dec 20, 2009 5:16 pm
What is the difference from a regular bevel?
PostPosted: Mon Dec 21, 2009 12:00 am
Picture Please.
PostPosted: Mon Dec 21, 2009 1:35 am
First name: Heath
Last Name: Blair
City: Visalia
i had no idea prior, but i found this on Sheldon Schwartz's website. interesting.
sweat the small stuff.
PostPosted: Mon Dec 21, 2009 1:38 am
First name: Heath
Last Name: Blair
City: Visalia
sorry about the small picture. heres the link.
http://www.schwartzguitars.com/oracle.htm
PostPosted: Mon Dec 21, 2009 7:09 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I'm confused, idunno. I thought the purpose of the armrest was to prevent the forearm from resting on the top and thus reducing the vibs of top?
Last Name: Johnson
State: CO.
PostPosted: Mon Dec 21, 2009 9:44 am
Thanks guys!
I hav'nt deeply understoud your answer Chris but I will take time to train much more my english and open some dictionary to make your discours clearer!
Bob3: In fact, I don't want an armrest (your definition is good) but a bevel (bending a part of the top to have a better comfort for the right arm)
I've sent a mail to scwart guitar about his way to do it.
Cedric
PostPosted: Mon Dec 21, 2009 10:06 am
City: Lawrence
Zip/Postal Code: 66047
Looks interesting. Let us know what you find out
PostPosted: Mon Dec 21, 2009 11:13 am
Looks to me as if there is likely an inserted extra wide shaped bevel lining added to the rim assembly in the arm rest area with the radial taper sanded in. Then the top is likely thinned in that area to aid forming over that shaped lining at glue up. To my eye this would be a simple bevel to pull off.
PostPosted: Mon Dec 21, 2009 11:21 am
Some are designed to achieve exactly what you state. But typically bevels are designed simply to elevate the discomfort in the right arm where it meets the body caused by the typical 90 dgree angle between the rim and top.
PostPosted: Mon Dec 21, 2009 11:23 am
Wouldn't that be pretty hard to synchronize the bend in the brace to the radius in the lining? I am just a bit confused on the execution.
PostPosted: Mon Dec 21, 2009 11:32 am
I would assume the lower X would inlet into the shaped lining therefore be some what shorter on that that side. I don’t see that as being an issue. of course not seeing the bracing pattern all I can do is surmise
PostPosted: Mon Dec 21, 2009 1:33 pm
First name: Fred
Last Name: Tellier
City: Windsor
What ever Sheldon does under the top does not seem to effect the tone or volume of the guitar, I played J.B. Davis' Schwartz and it was a real cannon. He has obviously done some brace re arranging to pull this off. As to Chris' comment of loosing valuable top area I don't think it is that serious of a loss, as our arms deaden that area and if done properly the top should still retain its ability to vibrate though probably a little less than without the bevel.
I hope someone who has seen what is done to accomplish this or has done one will enlighten us on the methods.
Fred
Fred Tellier
PostPosted: Mon Dec 21, 2009 7:25 pm
Location: Between Bordeaux and the Atlantic. S.W.France
How about this one. Don't know how it's done... It's an Iberica, and that's about all I can find out about it.
PostPosted: Tue Dec 22, 2009 2:53 am
First name: duh
Last Name: Padma
Your right Michael,
It really is a piece of cake. The only slightly difficult part would be trying to fit rectangular banding into a compound rabbit...which is what most will attempt...and find that the banding wants to twist. The secret is to use square banding as a square can easily take a compound bend and leave a perpendicular to the rabbit edge. Just slightly round off the inner edge before gluing it into place. Then its scraper time.
Once you know were you wanna sculpt, shape, curve or bend a surface, brace it accordingly and go for it.
Nearly all of the "edges" on my builds are compound curves...there are no flat surfaces like parallel side ribs or backs or tops, the entire instrument is one organic free flowing surface, so I am dealing with this sort of stuff all the time. Fret board excluded. Now if I could only figure out how to get strings to hold a curve under tension...
Just think of it ...curved necks with curved strings. But me don't think it gonna happen laughing6-hehe
blessings
the
bend outta shape
Padma
PostPosted: Tue Dec 22, 2009 6:21 am
It is done:
1: the tools
2: cut the top half its thickness with fret saw (not to cut trough !!)
3: place some spruce under the future bevel
4: spay some water
5: put a hoted brass rod on the top
6: downward pressure with a wood bloc ( brass is very hot)
7: Done
It took 10 minutes
PostPosted: Tue Dec 22, 2009 4:13 pm
First name: Nelson
Last Name: Palen
Geez guys, keep bending those plates and you're gonna end up with an archtop, for crying out loud! bliss
Users browsing this forum: Bing [Bot], J De Rocher, Kbore, rbuddy and 13 guests
