It is currently Tue Aug 05, 2025 1:36 am
 Post subject: What's best
PostPosted: Sat Dec 19, 2009 5:15 pm
First name: Tim
Last Name: Caccamise
City: Moreno Valley
Zip/Postal Code: 92557
I am going to inlay the top and back of an O with abalone, should I get some curved strips, or use straight and break them to fit the curve?
Tim
 Post subject: Re: What's best
PostPosted: Sat Dec 19, 2009 5:17 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
The easiest would be ZipFlex.
http://www.advancedshelltech.com/
PostPosted: Sat Dec 19, 2009 10:27 pm
First name: jack
Get the curved ones; you'll still have to break them, most likely.
PostPosted: Sun Dec 20, 2009 9:15 am
If using real shell, I find it best to use a mix of straight and curved .. about 70-30 or so straight/curved. The straight ones work bertter on the lower bout and around the neck joint area, the typical curved ones ahve too much radius as they are usually made for a rosette.
on my first ever I used only straight paua strips ... and on a florentine cutaway as well.
Oh .. and use the teflon filler strip ....
PostPosted: Sun Dec 20, 2009 5:29 pm
Last Name: Shaw
City: Philadelphia
Have you used this? This stuff has some type of elastic in it right. How does this stuff scrap and sand. What minimum radius can this stuff be bent to? Wanted to give it a try but was wondering about this....Mike
