It is currently Tue Jul 22, 2025 2:18 am
PostPosted: Wed Oct 14, 2009 2:08 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Well I have my vac/press system up and running, I have built a press for bracing and I would like to build one for the bridge. I hate to fork out $100+ for LMI does anyone have pics of bridge clamps they have built
thanks
Richard
PostPosted: Wed Oct 14, 2009 3:33 pm
Richard, check out the tutorials section, there is a recent thread there with a plan to download and pictures as well. here's a link for you viewtopic.php?f=10117&t=23895
I'd like to see some pictures of you vacuum set up as I plan on setting up soon as well. I have a Gast pump, an old compressor with a blown motor (I'll be using the tank as a reservoir) and nothing else, so I'd love to see pictures of your set up.
PostPosted: Wed Oct 14, 2009 3:35 pm
City: Duluth
State: MN
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Thu Oct 15, 2009 5:12 pm
Last Name: Garrish
That's some nice minimalist engineering, right there. A vacuum clamp is just a membrane, a seal, and some way to get the air out.
Bob Garrish
PostPosted: Fri Oct 16, 2009 4:13 pm
City: Duluth
State: MN
Well, I didn't mean for it to be "end of subject" when I posted that pic. That's one way to do it. Let's see some more!
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Thu Nov 26, 2009 11:58 am
First name: Kathy
Last Name: Somerville
City: Edmonton
State: Alberta
Zip/Postal Code: T5S 2V8
Dennis,
Where did you get the white plastic fitting for the end of the vacuum hose?
Kathy
PostPosted: Thu Nov 26, 2009 12:20 pm
City: Duluth
State: MN
ksomerville wrote:
Dennis,
Kathy
Hi Kathy,
That came from FiberGlast. They sell the vacuum film as well as the valve.
The Vacuum Connector (valve) is about half the way down on this page: 891-A Vacuum Connector
The vacuum membrane is on this page : 578-A Nylon Bagging Film about half way down, and the 581-A Gray Sealant Tape is near the bottom of that same page. That tape came off cleanly from KTM-9 finish, and I know it comes off cleanly from other finishes as well.
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Thu Nov 26, 2009 12:31 pm
First name: Matt
Last Name: Rispoli
State: NJ
[clap] great job dennis.
PostPosted: Thu Nov 26, 2009 12:43 pm
Mine isn't quite as minimalist as the one Dennis posted.
Mine is made from a scrap of lexan (1/4 thick). For the membrane, I cut the end off a exercise rubber band they sell for pilates and yoga (my wife bought them at a garage sale). The gasket is a bit of a foam rubber yoga mat with a hole cut in it (no butt seams to leak like with using weather stripping) - again from a garage sale. The only new part was the brass hose connector which is screwed into a hole I tapped for the threads. The membrane and foam rubber are attached to the lexan with a bead of super glue. Total cost was less than $5.
John Cross
PostPosted: Thu Nov 26, 2009 11:43 pm
First name: Kathy
City: Edmonton
State: Alberta
Thank you for the links, Dennis.
John, your design is also quite simple and good - thank you for posting.
Kathy
PostPosted: Fri Nov 27, 2009 1:03 am
What pump or motor setup are you guys using?
-jack handy
PostPosted: Fri Nov 27, 2009 6:52 am
City: Duluth
State: MN
John Cross
John, this looks interesting. Good (re)use of cheap resources!
Can you go into more detail about how you made yours? You've got a piece of Lexan with a hole big enough for any bridge you make, and onto the bottom of the Lexan, you've glued a piece of rubber yoga mat of the same shape as the Lexan. (I've made vacuum templates/jigs for a pin router, so I "get it" when I see the hose connected, but you may want to explain that in detail for others that may be interested in doing it your way. I used quick-disconnect air hose fittings for the connector - I can't see yours very well in the photo but it seems like you used the same or similar.)
Looks like you've also glued an additional piece of the membrane material onto the bottom, covering the yoga mat/gasket. Did you seal the edges where the membranes meet at the exterior?
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Fri Nov 27, 2009 7:25 am
First name: Matt
Last Name: Rispoli
State: NJ
john can you go into a little more detail about it. I like the design.
PostPosted: Fri Nov 27, 2009 12:09 pm
Here is a bit more detail about how I made mine.
The lexan scrap is about 4x9 give or take. I cut a hole bigger than the bridge I use offset to one side (about an inch clearance for the bridge all around) and eased the edges so there were no sharp corners to catch the rubber membrane. In the side that didn't have the hole for bridge clearance, I drilled and tapped a hole to fit a standard brass fitting (since it is a pipe thread, make sure you tap it from the same side as you will be attaching the rubber mebrane and only go deep enough to have the brass fitting go almost all the way through the frame). The brass fitting I used has pipe treads on one side and barbs on the other so you just press your vacuum hose onto it after it is threaded in (wait to thread it in until after all the other pieces are glued on). Run a bead of super glue all around the bridge clearance hole (but not the hole for the brass connector) and put on the rubber membrane taking care to make sure it wets out the glue all the way around and there are no wrinkles. You don't need a lot of glue - just enough that there is a continuous bead. While that's curing, take the foam rubber mat and cut a piece the same size as the lexan scrap (i.e. 4x9). Cut a big hole in it so that the edges are about a half inch wide all the way around. Run a bead of glue around the edge of the rubber mat ring and press that onto the other side of the lexan frame. After that cures, screw in the brass connector and attach you hose (which has a quick connect fitting on the other end to actually attach to the vacuum pump).
I drew up a picture of the parts if that isn't clear enough.
As for the vacumm pump I use, I got a diaphram pump from Joe woodworker because I wanted something quiet. If that wasn't a issue, there are cheaper otions.
PostPosted: Fri Nov 27, 2009 9:01 pm
City: Duluth
State: MN
John Cross wrote:
... Run a bead of super glue all around ...
Thanks, John.
I guess what's so surprising is that superglue holds the membrane onto the Lexan. I think of superglue as drying pretty brittle. I'll have to try and see if thick CA will hold the Nylon film that I have. I like the clear Nylon membrane, as you can see if anything has shifted during clamping.
It still appears to me that you have glued the green membrane both to the top (which is the part that stretches and gets vacuum sucked down), as well as an additional membrane covering the yoga mat (thin neoprene?), or does the yoga mat just happen to be the same shade of green?
Vacuum Pumps:
I did some research to see which Gast vacuum pumps would pull at least 25 to 28 inches of mercury (in Hg), because that is what Grant Goltz told me would be adequate clamping pressure. (Grant also builds drop-dead gorgeous kayaks, vacuum forming veneers with epoxy resin and cloth.) Once I knew how strong the pump needed to be, I watched Ebay until I found a used one for (I think it was about) $30 + shipping. They are way too expensive to buy new, for most non-full-time pro luthiers. The other thing I bought was a vacuum gauge, so I would know when the vacuum was at or near the 25 to 28Hg range. I found it to be critical, because without a gauge, you won't know if the seal is tight, and you may be pulling less, for example if you were pulling 15 inches Hg, the membrane would be stretched, and you would have no way to know that you got inadequate clamping pressure (until the bridge popped off later.)
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Sat Nov 28, 2009 4:08 pm
Last Name: Garrish
CA will hold it. It's by far the best glue for the application, actually. I think it gets a bad rap for the combination of being harder to use properly than hide glue and less traditional than epoxy, but it's a really great adhesive for many things if that doesn't scare you off :)
Bob Garrish
PostPosted: Mon Nov 30, 2009 11:29 am
Dennis said "It still appears to me that you have glued the green membrane both to the top (which is the part that stretches and gets vacuum sucked down), as well as an additional membrane covering the yoga mat (thin neoprene?), or does the yoga mat just happen to be the same shade of green?"
The rubber yoga mat and the stretchy membrane are the same colour (just luck - not intnetional). The stretchy membrane gets glued to the top of the lexan frame (same side as the brass fitting threads into). I don't know what kind of rubber it is but it is pretty tough. The yoga mat gasket gets glued onto the bottom of the lexan frame. No second layer of membrane.
My first version of this looked more like the one LMI sells (i.e. bolted together) and used weather stripping as the gasket. It was a complete failure - leaks, took a long time to build, looked even uglier than this one. This version will hold a vacuum for about 25 seconds after I turn off the pump.
PostPosted: Mon Nov 30, 2009 2:02 pm
Last Name: Abercrombie
Dennis-
Thanks for the FiberGlast link- I had been looking around for latex and other stretchy materials for a while. It looks like the Stretchlon material will do the trick (500% stretch).
PostPosted: Mon Nov 30, 2009 7:39 pm
City: Duluth
State: MN
JohnAbercrombie wrote:
Dennis-
John, If I knew you really well, then I would tease you about being excited to have found a latex store. I would also warn you not to make your suit too tight. However, I don't know you well enough, and so will have to hold off. :lol:
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Mon Nov 30, 2009 8:03 pm
Dennis-
Dennis
:lol:
Dennis-
Yeah, well on second reading it does sound a bit like the fetish thing, I admit. I should have said 'I had been looking around for latex and other stretchy materialsstrictly in small quantities for vacuum guitar jigs', I suppose.
There's a whole bunch of stuff I just 'don't get' in life..... :oops:
PostPosted: Thu Oct 18, 2012 2:47 pm
Do you think something like this would work for a larger top brace in dish clamp?
John Cross
PostPosted: Thu Oct 18, 2012 4:16 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Dennis Leahy wrote:
This is actually the setup you would use to vacuum bag a 60ft fibreglass yacht! (slight scale difference though :D )
Dennis, doesn't the tacky tape mess up the finish? The stuff I've used is really hard to get off once you've stuck it down properly.
Edit: sorry, should have read the whole topic :oops:
Pablo Picasso
PostPosted: Thu Oct 18, 2012 5:08 pm
I'm in the "use what's at hand" camp.
Just a tuberculin syringe barrel stuck into the vacuum hose, a three way IV valve, and hypodermic needle. The needle is sealed to the bridge clamp with silicon caulk.
I recently had to clamp multiple bent strips on an undulating mold for a prototype for a guitar stand. For the port through the rubber membrane, I just cut out the injection port from an IV fluid bag and glued this to the membrane with Locktite Vinyl Fabric & Plastic Flexible Cement. Worked great for multiple clampings...just stuck the needle through the IV bag port, and your good to go.
For a pump I use the compressor out of an old freezer, an old propane tank from the BBQ (flushed out with Nitrogen first !) as a reservoir, and the control stuff which you can get from Joe Woodworker site. Quiet as a mouse.
PostPosted: Thu Oct 18, 2012 7:42 pm
I did a tutorial on one. It's in the tute section.
Users browsing this forum: No registered users and 40 guests
