It is currently Tue Aug 05, 2025 6:44 am
 Post subject: Body Depth
PostPosted: Fri Nov 13, 2009 6:57 pm
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Zip/Postal Code: 43201
Hi everyone,
I am going to bend my first set of sides tomorrow. I figure it would be good to cut the profile of the body depth before bending. When builders list body depth of a guitar at 4 5/8", do they generally mean the entire body depth (including thickness of the top and back plate) or the height of the tail block and neck block (internal depth of the body of the guitar). Thanks!
Peter
P.S. I successfully joined up two tops today - victory 1 of build 1. :)
 Post subject: Re: Body Depth
PostPosted: Fri Nov 13, 2009 8:52 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Peter,
As I understand it, the "single" body depth you referenced is the depth at the tail block. The depth at the neck is usually
significantly smaller, so the body is tapered. Some people theorize that this taper helps keep the guitar from having a
single, very high Q, air resonance.
As far as cutting it ahead of time, I think it would be dangerous to try and cut the sides to exact dimensions. Since both
top and bottom are curved, the sides are not a straight taper. Some of us cut the back profile into the bottom edge of
each side before bending, because the bottom has the most curvature. I always try and leave 1/8"- 1/4" extra along the
top edge, to allow for any small mis-alignments in gluing the sides up in the mold. It's not difficult to take that much off
with a small hand plane, and then finish off with a sanding dish.
Gene
PostPosted: Fri Nov 13, 2009 9:20 pm
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Thanks, Gene. That was very helpful info.
If the body depth at the tail block is listed as 4 5/8" for instance, does that mean that the tail block is about 4 3/8" tall (4 5/8" minus a 1/8" top plate and 1/8" back plate)?
Peter
PostPosted: Fri Nov 13, 2009 9:27 pm
Yes, that is correct Peter. Just subtract the top and back thickness to get your side depth (width, depending on how you look at it). I don't think many people use a 1/8" back plate thickness though. I tend to go for 0.090-0.100"
Measurements of guitars are generally given as finished measurements.
PostPosted: Fri Nov 13, 2009 9:29 pm
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Thanks for the reply, Rod. Got it!
PostPosted: Sat Nov 14, 2009 9:55 am
One advantage in bending sides unprofiled is that if you have an edge crack or ripple you can often just plane it off. I was taught to bend sides at their full height, clamp them in the mold, scribe the lines from a template and then plane them down. ( My teacher actually used a coping saw- but this tends to split along the grain lines, at least in IRW). Good luck with your build!
In Markham,Virginia
PostPosted: Sun Nov 15, 2009 1:39 pm
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Thanks, Jon!
Users browsing this forum: Bing [Bot], bobgramann and 35 guests
