It is currently Mon Aug 04, 2025 3:32 pm
PostPosted: Thu Nov 12, 2009 4:32 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Hi!
I just received a nice lumber of nicely figured Hard Curly Maple. about 7/8" x 6¾" x 49".
At one end, grain is almost quartersawn on both sides...from maybe 80 to 60 degrees, and in the center (a 2-3inch section), it more like 45 or less. Almost flat in the perfect center.
At the other end, it is a waved (2-3 waves) flatsawn.
What would you do to get necks from there? they're gonna be bass necks, so 32-34 inches long. I've few idea, would you give my your point of view?
1- Take the flat end, and make 2 solid flatsawn necks.
2- Take the flat end, turn it 90 degrees, and make 3 pieces neck, maybe with laminations (purpleheart, bloodwood, IWR, Ebony, don't know). To get it quartersawn.
3- Take the other end, cut off the center, and laminate the 2 almost-quartersawn sides, with an other hardwood lamination in center.
Thanks a lot!
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Thu Nov 12, 2009 4:53 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
Hey,
I used to use neck material that had some run out for some of my earlier basses - but after dealing with it while wanted a very playable bass, I started using laminations - adding in some cases very small strips where needed in order to get quartersawn necks. It seems to be a lot easier to find perfectly flatsawn wood that can be turned in perfectly quartered necks with a little help.
Stephen
www.ziegenfussguitars.com
PostPosted: Thu Nov 12, 2009 4:57 pm
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
Not sure what will work best for you, but would recommend a laminated/layered neck to anyone. I like the look and they are plenty strong.
-Matthew
