It is currently Sun Jul 20, 2025 2:33 pm
 Post subject: Bloodwood...
PostPosted: Tue Nov 03, 2009 10:36 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I Had my first expérience with bloodwood, and i'm bit sad!
I've cut 2" x 4" by about 3/16"-1/4" thick blanks (to make guitar picks). I had in mind to get out few fingerboard of my lumber, but my little blanks have all BROKEN with a little pressure applied by finger... WHAT IS THIS!? It was breaking like you can broke spagettis, i swear... Ok, grain was like at 50-55 degrees not quartersawn, but anyway, it's supose to break like this, hu?
Please tell me they're was a problem somewhere...this wood is too beautiful to not use it for fingerboards!
Francis Richer, Montréal
Les Guitares F&M Guitars
 Post subject: Re: Bloodwood...
PostPosted: Tue Nov 03, 2009 10:53 pm
Last Name: Dunn
City: Wurtsboro
State: New York
Zip/Postal Code: 12790
is the grain direction perpindicular to the strings when you strum? I have never played with a wooden plectrum, so I am not sure of design, but i would imagine they should be rather thick. 3/16" w/ grain perpindicular to strings?
It is better to try and fail, than never try at all
PostPosted: Tue Nov 03, 2009 10:58 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
I didn't made the picks yet...
PostPosted: Tue Nov 03, 2009 11:59 pm
Last Name: Cox
Quite a few of those tropical hardwoods are splitty and cracky when you get them thin... but 1/4" is still pretty thick. I haven't had a problem with Bloodwood being more easily cracked than most any others, though...
Possibly, you got a bad piece with either a drying defect or some sort of Wind shake defect in it (Where the rings delaminate from eachother in the wood..)
I think I would use Flat sawn wood for picks... I could see a thin piece folding along grain lines and splitting.
PostPosted: Wed Nov 04, 2009 6:09 am
It sounds like you cut your blanks from the end grain. If that's the case, almost any wood would do that.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Nov 04, 2009 11:51 am
What Laurent said,
Plus what does a fret board have in common with a pick as far as suitability or qualities of a particular type of wood are concerned ? The demands of a pick are very different than a fret board so even if you aren't using end grain the failure of your wood to make a pick doesn't preclude it from being used as a fret board.
Link
