It is currently Thu Apr 23, 2026 12:45 am
PostPosted: Mon Nov 02, 2009 8:25 am
Proof that one should keep his mind on what he is doing; my top plates are about 85 thousands. Any chance of using this top for a D size accoustic?
RJS
PostPosted: Mon Nov 02, 2009 9:03 am
Country: Romania
I guess not, better it aside for a small guitar...
Build log
PostPosted: Mon Nov 02, 2009 9:06 am
Well, it's definitly on the thin side of things.
If I were you and the guitar was planed for me, than I'd give it a try. If it's for a customer, than a new top is the safer solution.
Alain Moisan
(Now building just for fun!)
PostPosted: Mon Nov 02, 2009 9:26 am
First name: Big
Last Name: Jim
Sounds like someone needs to try there hand at a mandolin with that wood . LOL welcome to the darkside ! laughing6-hehe
PostPosted: Mon Nov 02, 2009 9:36 am
You could build a size 2 also. Mine are around 0.090. You could get by with .085. Get another top for your Dred.
PostPosted: Mon Nov 02, 2009 9:52 am
It all depends on how stiff the wood is.
PostPosted: Mon Nov 02, 2009 12:21 pm
Last Name: Cox
I would happily use it on an L-0, Ditson GC, O size or most anything with a lower bout less at 14" or less....
A Ramirez or Torres style classical also comes to mind here...
Can you make a Dread out of it? Sure.. you can build a Dread out of it.... Properly braced, it won't come apart... Is there a possibility it will come out too thin and you will need to run light strings on it... Yep... Will it sound good? Possibly, though it won't be a Bluegrass cannon....
Good luck
PostPosted: Mon Nov 02, 2009 12:27 pm
I am with Todd here. This a perfect opertunity to try your hand at a double top :D
PostPosted: Mon Nov 02, 2009 1:21 pm
City: Bend
State: OR
Zip/Postal Code: 97703
0.90 is not too thin, but thickness is really trivial. It all depends on the stiffness. I had some lutz that I used for a 12 string SJ and I ended up with 0.89. Yep and SJ and a 12!!!! To date, acoustically, my finest instrument. I use deflection to test stiffness and use different degrees for different size bodies etc
PostPosted: Mon Nov 02, 2009 1:40 pm
Last Name: Speller
City: Rodney
my first was an OM sized guitar and thicknessed the top to .09" graduating to .085 at the edges. and its sounding fine and there has not been a problem with it yet. i would guess .085 would work just fine.
PostPosted: Mon Nov 02, 2009 2:12 pm
Country: Romania
Yes, but 09 finished thickness and likely good wood is one thing, 085 going down to 08 finished (even less if something bad happens, and it usually does), of unknown quality wood, is quite another thing.
One option is to change the bracing some. Bigger X, 3 tone bars (like on a 12 string) and a 3x3 lattice in the lower opening of the X.
Build log
PostPosted: Mon Nov 02, 2009 2:18 pm
It all depends on the wood, and unless you have some reliable way to test it ther'es no way to know. Most people are not nearly as good at 'flex testing' as they think they are, and something more objective is best. I've got tops that might be OK on a Dread at .085",(although I'd put them on an OM or smaller) and others that I'd be leary of using on a classical at that thickness.
PostPosted: Mon Nov 02, 2009 3:49 pm
If you did not want the top this thin don't use it
You have only a small investment in this top at this stage better to start again.
IMO bracing should not be used to compensate for a too thin and flexible top.
The top still has to span between the braces.
Keep it for a small instrument or cut it into back reinforcement strips.
PostPosted: Tue Nov 03, 2009 9:04 pm
Thanks for all your comments. A great forum indeed.
RJS
Users browsing this forum: DennisK and 44 guests
