It is currently Wed Apr 22, 2026 1:01 pm
 Post subject: Where do you get dye?
PostPosted: Sun Nov 01, 2009 11:22 am
First name: shad
Last Name: peters
i am amidst the build of a single cutaway electric guitar and i have decided to do a burst on it. this will be the first burst that i have ever done so i have been looking around and researching a good bit trying to get information on what methods there are and the correct way to implement them. i think i have decided on using aniline dye's to to achieve the effect im looking for, but im not sure where i should purchase the dye from, or if i should get water based, or oil based, or whatever other kind of base there may happen to be. soo... to get down to the question where do you get dye from? and what are the pros and cons, of the water base, vs. the oil base?
any other tips or suggestion that you may have regarding the use of this stuff would also be appreciated. im definitely going work with some scrap wood first, but beyond that are there any headache avoiding tips?
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Sun Nov 01, 2009 11:58 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use Trans-Tint dyes, mixed with shellac. You can get the dye from OLF sponsor Rockler
http://www.rockler.com/product.cfm?page=11448&filter=dye The dyes will mix with a bunch of different finishes, but, like I said, I mix them with shellac under whatever top coat I use.
PostPosted: Sun Nov 01, 2009 4:38 pm
PostPosted: Sun Nov 01, 2009 10:18 pm
First name: shad
Last Name: peters
i did a search on here earlier today and found that video, i tried to watch it but it just kept saying an error occured. then later when i was searching for other videos on you tube i found it there as well and it wouldn't play. long story short, i have tried watching it like four times today and something is either wrong with my computer or the video.
~shad peters
PostPosted: Mon Nov 02, 2009 12:15 am
I think the problem might be with Youtube. I got the same error message when trying to watch some videos on Youtube today. I just checked the Sunburst video and it appears to be working fine.
PostPosted: Mon Nov 02, 2009 10:00 am
Stewmac translucent dye and Transtint both are great dyes. I use both and the ratios need for various tints seem to be identical.
PostPosted: Mon Nov 02, 2009 11:31 am
First name: Woodrow
Last Name: Brackett
City: Grover
Stewmacs "Colortone" dye is actually Transtint, and I just noticed it's actually cheaper from Stewmac.
