It is currently Wed Jun 10, 2026 3:06 pm
PostPosted: Wed Oct 21, 2009 7:59 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Tru Oil over cellulose pore fillers? Yes. Over most anything oil based (like oil stains)? Given some drying time before applying the Tru Oil, I'd say yes. Over shellac? A qualified yes, because it depends what is under the shellac. Over other stuff? Maybe. Maybe not. Listen to other people for that answer. It's versatile stuff, but it's not a silver bullet. I love the stuff, but I don't ever pore fill with epoxy. I'm glad I read this thread, because I was considering doing that real soon.
PostPosted: Wed Oct 21, 2009 8:10 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I'm back with a question that only occurred to me about ten minutes after my previous post. I realize many of you don't have the luxury of long waiting times between finish applications and so forth. But what about allowing a long curing and out-gassing period after applying epoxy? For example, if a hobby builder who wasn't on a schedule could hang the guitar up for a month or more before applying top coats of finish, do you folks think an oil varnish product like Tru Oil would be okay then? Or is this a more or less perpetual problem? Thanks in advance.
PostPosted: Wed Oct 21, 2009 11:21 pm
To be clear, Epoxy doesn't "off gas" like a finish that has a solvent carrier. There is no solvent or I should say there is usually no solvent added to epoxy. ( one can add solvent to thin epoxy and some epoxy water proofing products have a high solvent content. ) So in the sense you are thinking of off gassing this is not what is happening with epoxy. Also epoxy pretty much cures in the time period for that epoxy. Temps and thickness of application affect this but most of the curing will be for all purposes done in the 5min. or 5 hr. time that most epoxies fall into. Letting it sit will not solve the amine blush deal. This will persist unless you remove it. The amine doesn't always form and some epoxies are not prone to amine blush. I suspect Z-poxy is one of them. I have not researched it so I can say for sure.
L.
PostPosted: Thu Oct 22, 2009 3:23 am
Link is on the money, Amine blush, which is actually hydrates of amine carbonate building upon the surface of the epoxy as it cures, is created as a result of an exchange between the amino acids (amines) contained in the hardener of 'most' epoxies, and the available CO2 and moisture in the air. The resulting 'blush' appears as an oily substance which can go completely unnoticed unless the cured epoxy surface is very carefully examined. No amount of waiting will remove amine blush, and sanding can quite often only result in spreading it over the work surface. Also, hydrates of amine carbonate will not wash from the surface using thinners or naptha and attempting to do so will mostly only move it from one place to the next on the work surface.
As i mentioned earlier, amine blush 'can' be washed from the surface of the work piece once it has fully cured using warm soapy water and an abrasive pad and then sanding before application of the finish. The reason I have suggested to simply avoid epoxy under any kind of polymerising finish such as Truoil is because the required process offers no real certainty that you will not encounter problems down the track. The odd thing with amine blush is that the finish can look and feel fantastic for a number of months and then the fuzz begins to appear to break your heart. The problem with this delayed reaction is that by this time it rears it's head, epoxy has fallen right off the radar and the finger usually gets pointed at the acids in the players sweat, poor quality finishing product or any number of other possibilities our minds can come up with. Often the only thing that will resolve the issue is to rub the finish back to bare wood and once that resolves the issue, what ever had been the assumed cause prior to work commencing, has now been 'proven' to be accurate regardless of how inaccurate it had been. The sad thing here is that no one learnt noth'in from the experience. Worse that that is the vindicated then run around telling everyone how bad this product was or that one was because they just do not understand what had really happened.
Anyhow enough of that rant. As to why some epoxies will blush and some not, you will find that this has to do with the 'type' of amines used in the manufacture of the hardener. Low blush epoxies generally cure softer and more pliable so they may not sand all that well. High blush products like Zpoxy cure to be more brittle, this is why they sand well. On that note it should be considered that there appears to be a relationship between contact dermatitis and high blush epoxy products. Some people who develop a sensitivity to epoxy can still tolerate working with low blush products like some of the West Systems lines but must avoid high blush products like the plague.
These factors aside, as Michael points out you can indeed use high blush epoxy such as Zpoxy and never encounter an amine issue. This is because in order for hydrates of amine carbonate to form during curing, both CO2 and moisture must be present in a high enough count to cause the exchange. So if you insist that you simply must use epoxy, the best bet would be to wait until the RH drops very low and be sure there is plenty of fresh oxygen rich air circulating around before you think about mixing part A with part B, or you could just fill with so many other products that it makes me wonder why anyone would bother using epoxy under a polymerising finish such as Truoil.
P.S. To be clear, just in case i was mis-read and it is assumed i had suggested that 'epoxy' gasses off, i had not. Rather i had suggested that 'Truoil' will continue to gas-off as it cures over a period of some weeks to months and this process could cause issue when reaction occurs between the surface of the finish and the synthetic micro fibers of a guitar case.
PostPosted: Thu Oct 22, 2009 8:25 am
James W B wrote:
You mean there`s nothing on the neck but CA? how many coats.
James
pore fill + 6-8 coats of Starbond med thick. I apply wil nitril gloves and wipe on with my finger. I have experimented with polypropolene brushes but I do a better job with my finger. I pay $32 for 16 oz and it takes less than 3-4 oz counting any waist so roughly $6-$8 of CA. plus sand paper. apply two sessions allow to cure over night. sand level. do that 3 times. Once the finish is on an leveled sand through 1500p and then go to the power buffer. It polishes very well. It is very hard and makes for a very fast playing neck. Slick a bat guano.
PostPosted: Thu Oct 22, 2009 8:30 am
First name: Patrick
Last Name: Hanna
State: Missouri
Thanks, Kim. I think I understand a little better now. I'm glad you took the time to explain this.
Cheers!
Users browsing this forum: No registered users and 71 guests
