It is currently Mon Aug 04, 2025 5:15 am
PostPosted: Mon Oct 12, 2009 5:41 am
Last Name: Kitchen
State: SW Pa
I am about to shell out for 20 or so to stock up. What brand, what supplier do you like?
Hopefully one of our sponsors
PostPosted: Mon Oct 12, 2009 5:50 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I get 'em here. http://drillbitcity.com/
PostPosted: Mon Oct 12, 2009 6:10 am
http://bqtool.com/cart/index.php?cPath= ... 54cdddab21
I use these bits. The 1/32 bit is under .032 in diameter. They also are now making a .020 diameter bit. The prices is under $7 and these are industrial quality . They do the job in my shop .
PostPosted: Mon Oct 12, 2009 6:18 am
Last Name: Kitchen
State: SW Pa
Thanks for the quick replies.
What sizes do you reach for the most?
Fine detail, routing out the back strip and such.
PostPosted: Mon Oct 12, 2009 8:53 am
My dentist...all sterilized and nice in a little white envelope...no charge! [:Y:]
PostPosted: Mon Oct 12, 2009 12:33 pm
Hey john .. might those be the ones that Dave Nichols uses as well . I got some fomr him with my inlay base and they are pretty good.
PostPosted: Mon Oct 12, 2009 1:38 pm
yup
PostPosted: Mon Oct 12, 2009 2:37 pm
Last Name: Garrish
I get all my small cutters from http://www.precisebits.com/
I use 1/32" cutters quite a bit, though the majority of my clients have inlays that require a 1/64" and so I use those most. I've also got a box of 0.01" cutters that I use on some special stuff. If you're running them in a CNC with low spindle runout and accurate feedrates, then the quality of the cutters from PreciseBits is worth the price many times over. If you're running them manually or in a higher runout situation, then they might not be worth it.
Bob Garrish
PostPosted: Tue Oct 13, 2009 7:24 am
I agree Bob .. maybe its the manual routing that breaks them more often than the ones that Dave and John use .. I have both, and prefer the others over the precise bits .. I have yet to break one of those, but the first precise bits one lasted one inlay .. seem much more fragile (and they cost a lot more, especially to Canada .. they wont ship USPS, so you get the UPS fees .. ouch.)
PostPosted: Thu Oct 15, 2009 5:09 pm
Last Name: Garrish
They're really optimized for machine use, I think. I can run the same bit for hundreds of inlays; I've had one 1/64" cutter cut over sixty full fretboards worth of falling-leaf inlays (and I'm not sure how much more after that before it broke!). And they can cut much faster than other cutters, if used just right.
That said, it's a lot like using a glass tool: it's harder and sharper than anything else, but the tiniest slip destroys it.
Bob Garrish
Users browsing this forum: stumblin and 52 guests
