It is currently Tue Jun 09, 2026 5:33 am
PostPosted: Fri Jul 17, 2009 11:02 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
I am a newbie. I’ve been setting my guitars up for years. Nut action (files), neck relief (truss rod) and saddle action, inspection & cleaning. Just the light easy stuff.
I enjoy working with guitars would like to grow in knowledge and experience. Building a guitar some day may be in my future.
I recently got a guitar than needs some bridge work and a small crack repair. I have a bunch of questions and I hope some of you will be kind enough to help me.
The bridge was already loose except for 2 Gibson bolts. I got it unbolted and removed without any problems (without removing the bridge inlays and bolts from bridge). I was amazed at how easy the nuts unscrewed. The bottom of the rosewood bridge has some small fibers from the top which I intend to sand to get just down to clean rosewood. The top where the bridge needs to be re-glued looks good to me (what is in good shape with just a few spots were fibers are missing (stuck to the bridge). Some minor scraping/sanding to remove the little bit of old glue is all I assume I need to do to prep the top for re-gluing the bridge (correct?) Pictures are below. Here are my questions:
1. What kind of tape or other material do you use for masking the finished top while cleaning up the bare part of the top where the bridge is to be re-glued? (I see where Stew Mac warns against using their paper adhesive tape on older finishes.) Is blue painters masking tape OK on top finish?
2. I know I need to remove the finish that the original builders missed on the top under the bridge, and remove any remaining old glue. I intend to leave some of the groves in the top instead of taking more top wood away. Do you agree this is best to leave?
3. Since HHG will not work for filling voids (groves in top), I assume I should use Titebond to re-glue the bridge. Is this correct?
4. The scale length should be 24.75” (628.65mm). I believe, since this is short scale and light gage strings will be used, that compensation of 1/16” (1.6mm) on the treble side, and 3/16” (4.8mm) on the bass side of the saddle should be added. Correct?
5. I checked the scale length following a recommendation in Hideo K.’s I measured from the fretboard side face of the nut to the CENTER of the 12th fret and doubled the distance. Is measuring to the center of the 12th fret correct?
6. For determining saddle location, Hideo says to measure from the face of the nut to the FRONT edge of the saddle (sound hole side). I would have expected the measurement to be to the center of the saddle. What is correct way to measure this?
7. How do you keep the glue out of the bridge pin holes? (Use Stew Mc Locating Pins? Or is there a more simple technique?) http://www.stewmac.com/shop/Tools/Speci ... _Pins.html
8. Are slanted bridge pin holes normal? They are slanted so that the bridge pin heads point slightly back towards the endpin. I thought bridge pins should be straight up.
9. Would you touch up the finish around the bridge on a vintage guitar that had no other finish work done on it (is 100% original) or l
10. eave it as it?
11. If I (or have someone else) touch up the finish, should this be done before the bridge is reglued so it is easy to sand flush, etc?
12. If I (or someone) were to touch up top center seam finish break, when should this be done?
13. What is a good source (videos or books) for finish work and other repair (re-fret, neck re-set, crack repair) work?
I’m sure I’ll think of more questions, but this is a good start before I start this project.
Thanks for the help in advance.
Ed
PostPosted: Sat Jul 18, 2009 10:19 am
Ed, welcome to the OLF. I don't know the answer to all of your questions, but I've included my replies in the copied text below...
Blue painters tape will work. I use the lower tack versions and press the tape against a pant leg to lower its tack further before applying.
Most people would say that you should route that area flush. That's what I would do. It can be hair raising, but with decent jig, it's not so bad. One really needs a good gluing surface.
Titebond doesn't fill gaps either...hence the need to route the surface flush. But Titebond is a little more forgiving than HHG.
I take it you're making a new bridge? I find the vocabulary of compensation frustrating to deal with. The stewmac online fret calculator can tell you how long your scale should be on the bass & treble sides (at least in theory). How thick will your saddle be?
If the builder/company hasn't shortened the first fret in order to get frets 1-5 to play closer to in tune. There's an interesting series of articles on compensation by Mike Doolin that you might enjoy. Google will track them down.
I'll let someone else take a crack at that one.
I don't use enough glue that it matters. A little bit of glue in the pins holes is easy enough to ream out once the bridge is on.
Slanted saddles are more common. I'm not sure about bridge pin holes.
9. Would you touch up the finish around the bridge on a vintage guitar that had no other finish work done on it (is 100% original) or leave it as it?
I'll let the veteran repair folks take this one, but that sounds like a customer decision.
Again, veterans...
Best of luck to you,
Flori
PostPosted: Sat Jul 18, 2009 11:52 am
Last Name: Haney
First, Flori, sincere thanks for your help. My comments/answers are in this color below. Ed.
Most people would say that you should route that area flush. That's what I would do. It can be hair raising, but with decent jig, it's not so bad. One really needs a good gluing surface. Yes, this would be hair raising! But I think I could stomach it. The problem I see is thinning out the top as much as 2/64" when the top is about 7/64" thick at the sound hole. Also the top area at the birdge has a slight upward bellow in the rear and very slight dip in the front, all as would be expected in a guitar over 50 years old. I'm not sure how, or even if you would want, to make this flat. Seems to me that it would need to be routed smooth, not flat. And the clamping of the bridge would make it flat when drying. How would I go about routing it? What size router and what kind of set up?
Titebond doesn't fill gaps either...hence the need to route the surface flush. But Titebond is a little more forgiving than HHG. Is there not some filling glue that would work to avoid the routing and maintain more top thickness? This will also lower the birdge slightly which should not be a big deal since the saddle can be raised.
I take it you're making a new bridge? I find the vocabulary of compensation frustrating to deal with. The stewmac online fret calculator can tell you how long your scale should be on the bass & treble sides (at least in theory). How thick will your saddle be? My saddle original is 1/8" and not slanted. No, I am not building a new bridge. I will use the original bridge to maintain vintage value. There is also nothing wrong with the existing bridge or saddle. It just needs to be sanded smooth to new rosewood on the bottom. My understanding is that I need to put the face of the trebe side of the sadde (high E string saddle face) 630.25mm (628.65+1.6=630.25mm) from the nut face at the highe E postion. And put the low E string sadde face 633.45mm (628.65+4.8=633.45) from the face of the nut at the low E postion.
If the builder/company hasn't shortened the first fret in order to get frets 1-5 to play closer to in tune. There's an interesting series of articles on compensation by Mike Doolin that you might enjoy. Google will track them down.All my color comments in #4 above is coming from my common sense, not experience or clear explainations from Hideo, which are very lacking. So I still need confirmation of my understanding or be pointed to a very clear source that will give me bottom line numbers to use and EXACTLY where to take the measurements from and to.
I don't use enough glue that it matters. A little bit of glue in the pins holes is easy enough to ream out once the bridge is on.Yes, good point, thanks.
I'll let the veteran repair folks take this one, but that sounds like a customer decision.I am the customer on this one, and want to maintain maximum vintage value. So I'm looking for what luthiers opinions are on this for collectors' minds regarding value.
Again, veterans...
12. If I (or someone) were to touch up top center seam finish break, when should this be done? This finish break is extremely small but can be felt more than seen.
Flori
PostPosted: Sat Jul 18, 2009 7:15 pm
I'll add my two penneth and I expect to be shot down in flames I've only done around 5 of these repairs and each situation needs gauging differently according to the amount of old glue showing in the tear out of the old bridge.
From your photos there seems to be a lot of fresh wood on the bottom of the bridge now I don't remove this it acts at a ke to getting the bridge back in its original location. Now I use 2 different glues an epoxy glue and cascamite which is powdered resin glue. Both of these glues have good gap filling properties and are creep resistant, cascamite will only bond wood to wood, so you need around 80% fresh wood in the tear out and it should well, if less than that I use araldite amd epoxy glue.
I carefully scrap as much original glue and finish off with a scalpel before gluing, then using the appropriate glue to match the original fresh wood percentage area, I glue and clamp 3 clamps. Probably not the correct way, but my oldest repair is 3 years of more and holding.
Formerly JJH
PostPosted: Mon Jul 20, 2009 2:03 pm
First name: Jyme
Last Name: Bale
City: Dickinson
Zip/Postal Code: 77539
I agree for the most part with the afore person, but do not use any epoxy ever unless you know exactly what you are doing. I have known guitar building veterans who have used epoxy to glue a fingerboard to the neck. It will never come off. Never touch the finish of a really old guitar at all unless you have refinished a dozen before, you never know what the finish is made of. Never use more glue than you need, you don't need a lot of sqeeze out to have a good bond. Hide glue and the white guitar building glue from LMI are the best. Never ever use Tite Bond on a guitar as the particular resins in it will make the parts of the guitar far more difficult to heat and pull a part for repair. I've been doing all types of repairs and building guitars for ten years now. No I do not have my own shop and do not work for a guitar retailer. I advertised on my car that I build guitars and people called and wanted repairs done and I do and love it. I french polish all my guitars and I think they sound better than any factory model just as I think any other builders does also.
PostPosted: Mon Jul 20, 2009 4:26 pm
Jyme, why would that be? I use epoxy for fingerboards and find it is one of the easiest glues to reverse, it responds very well to heat with no moisture.
David White, Toronto
PostPosted: Mon Jul 20, 2009 4:38 pm
That is not true. I glue all my fingerboards with epoxy and have removed several with heat. In fact, it's pretty easy to remove.
PostPosted: Mon Jul 20, 2009 6:07 pm
Last Name: Haney
Peter,
What epoxy brand and source do you use?
Have you ever removed a bridge that was glued with epoxy and if so, how? Was it as pretty easy too?
Your help is appreciated.
Ed
PostPosted: Mon Jul 20, 2009 6:12 pm
Ed, I have reversed West brand epoxy on fingerboards and it releases very easily...easier than titebond. I have never used it on a bridge.
Users browsing this forum: No registered users and 41 guests
